One of the biggest complaints I get is the text screen is too small. I generally agree. More recent computers actually have the ability to use a higher resolution, but do not take advantage of it in the default mode. This instructable is for more advanced users. Please get help before starting this project if you are at least the little bit unsure.
You will need to have the documentation for both your video card and for your monitor. You will see numbers like 640x48 800x600 1024x768. Take those numbers and use the lower of the two from the video card and the monitor settings. If you can only use 640x400 then stop here. The 640x400 is the default. there is a 320x200, but I have not see that in years,
In my case the highest resolution for the monitor was 800x600. Still a boost over the default 640x400 screen.
Lastly you need to find out what your Linux system uses to boot, Lilo (we will not cover it), Grub (aka Grub1) or Grub 2.
For our purposes we will be using Grub2 for the images. Pictures in this step are the original screen shots.
Remove these ads by
Signing UpStep 1: Grub (aka Grub1)
$ sudo vim /boot/grub/menu.lst
or if you do not have vim
$ sudo nano /boot/grub/menu.lst'
# (0) Arch Linux
title Arch Linux
root (hd2,2)
kernel /boot/vmlinuz26 root=/dev/disk/by-uuid/1069fde9-8696-49a8-bbec-b8f35458f4d9 ro
initrd /boot/kernel26.img
We need to choose the number for our monitor and graphics card. we need to look at the table to get a number that linux understands. We are just going to use the 256 line as colors are not critical for our test setup. In our case it is 800x600, so we would use 0x303.
| 640x480 | 800x600 | 1024x768 | 1280x1024 | |
| 256 | 0x301 | 0x303 | 0x305 | 0x307 |
| 32k | 0x310 | 0x313 | 0x316 | 0x319 |
| 64k | 0x311 | 0x314 | 0x317 | 0x31A |
| 16M | 0x312 | 0x315 | 0x318 | 0x31B |
You will need to translate the hex umbers to decimal. Using a search engine can convert it for you. We need to append vga=771 to the kernel line.
# (0) Arch Linux
title Arch Linux
root (hd2,2)
kernel /boot/vmlinuz26 root=/dev/disk/by-uuid/1069fde9-8696-49a8-bbec-b8f35458f4d9 ro vga=771
Check you woirk. Some times it might be a good idea to copy the original lines, so in case the numbers do not work you can always still get into the system.
# (0) Arch Linux
title Arch Linux
root (hd2,2)
kernel /boot/vmlinuz26 root=/dev/disk/by-uuid/1069fde9-8696-49a8-bbec-b8f35458f4d9 ro vga=774
# (1) Arch Linux
title Arch Linux default resolution
root (hd2,2)
Check your work, save your work, and reboot. You should not ge able to do the new resolution.
Computothought (author)
in reply to Feb 18, 2013. 11:00 PMReply
Not Nice
Visit Our Store »
Go Pro Today »
