Introduction: Powerful Shocking Device
this tutorial show you how make a powerful Leyden Jar which take the static electricity of your computer screen or tv and tranform it into a powerful shocking device.It s cool just to watch.
-plastic container
- 2 copper wire 8 inch long
- 3 foil of aluminum
-plastic lid
-round nut
-scotch tape
-plastic container
-plastic lid
-round nut
-scotch tape
Step 1: Inside Part
Cut a rectangular piece of foil large enough to line the cannister.place inside the cannister.Try and keep edges of foil smooth and straight, or they will "leak" charge. Make a bottom too.On this bottom, stick a 8 inch wire.put this bottom into the canister.
Step 2: Outside Part
Now cover the outside of the cannister.Again, avoid rough edges, and make sure the foil doesn't get in the way of the lid.Cut a second piece of wire about 4-5cm long and strip both ends.
Tape one end to the foil on the outside, so that the other end can be easily curved around to meet the other wire .
Step 3: Interceptor
now take a few cue tips (static interceptor) and place in a star shape.Make sure it touch the wire !
And place a round nut just on top.(Make sure it touch the wire too)
Step 4: How It Works
Let your leyden jart beside your screen for 5 -10 minutes The electrical static charge will be transfered, positive and negative charges accumulate from the two metal coatings respectively, but they are unable to discharge due to the glass between them. The result is that the charges will hold each other in equilibrium until a discharge path is provided. Leyden jars were first used to store electricity in experiments, and later as a condenser in early wireless equipment.
have fun but be careful it' s not a toy .
