If you'd like to see some finished products or view my other tutorials, check out my etsy shop & blog , or follow me on twitter ! Also, your constructive feedback on this tutorial is greatly appreciated! Thanks for looking and message me with any questions!
http://www.etsy.com/shop/anotherwaydesigns
http://anotherwaydesigns.blogspot.com/
http://twitter.com/anotherwaydsgn
Remove these ads by
Signing UpStep 1Materials
- embroidery hoop (only about $2 for a basic hoop, available at craft stores)
- mesh material (nylon, polyester, silk - something with tiny holes that can serve as a fine screen)
- Drawing Fluid (I use Speedball, available at most art stores)
- small paintbrush
- newspaper
- Screen Filler (I use Speedball, available at most art stores)
- plastic spoon
- screenprinting ink
- squeegie
- shirt or bag to print on
I've got a kit. I'm giving it a shot.
Plus I got to make myself some shirts with the kids' designs, which were very cute and funny! Thanks again for the instructable.
i have had results bleed or some areas not have ink even with a squeegie that is bigger than my printing area??
also i have a screen but there seems to be a lot of instructions that say i have to tape the edges?? can i skip that? it looks like you get around it.
can't wait for the reply, i have been put off trying again as my first to printing attempts have not worked (one invovling cleaning filler out, so i am going to read over your steps for that too)
thanks
also, since the screen is round, i didn't tape it. i do tape screens when i buy rectangular screens. if you have the $, i'd buy a screen from the store since they are stronger and tighter; if not, then this is a good cheap alternative.
Just one question as this will be my first attempt doing this myself, what kind of paint do you use? Does it have to say specifically "Screen Printing Ink", or will any kind of fabric type paint work? Basically I'm looking for what would be the most inexpensive paint but that would still wash and wear well. I see only one store listed in my city on Speedball's website, so I'm hoping I have more options than them LOL.
Another question, and I completely understand if you are not wanting to share, but I was wondering if you have a preference as to where you get good quality shirts and other things to print on, but at a good price? I've been on the search for a while but feel overwhelmed by the choices and not knowing who is really good with supplying these things.
The screen needs to have some important properties:
- It must have holes that are big enough to allow ink to pass through easily,
but small enough to allow the stencil to properly adhere.
- It needs to be rather stiff with only a small amount of give, so that it returns
to its original position instantly.
- It shouldn't be made of an overly-fibrous organic material (cotton, wool, etc),
as the fibers tend to soak up and hold in the ink,
and can degrade the quality of the print.
Silk or nylon ought to work, as those materials don't "shed" fibers.
The right screen material is key. The reason professional ones are called "silk screens" is because silk is the best material to use (it's fine, strong, doesn't shed, and keeps a good amount of elasticity, as well as re-use longevity). My advice is to try something out; start cheap, give it your best guess, and you'll quickly learn what makes a good fabric while not wasting money!
The mesh material I used is nylon from Jo-Ann fabrics. I looked for a material with tiny holes that looked like fine mesh. I'm not sure another t-shirt would work too well b/c the fabric may be woven too tight, and the cotton may absorb the ink instead of letting it pass through. You can also look for polyester or silk fabric with small holes. If you have an art store near you, stop in and check out the screen printing frames that they have, so you have an idea of what the mesh material looks like. Also, make sure the material isn't too stretchy (ie nylon stockings) b/c the material will move around during printing.
rogeromc23@yahoo.com
Congratz for the awesome tutorial.
love it ^^
A. had a hard time getting the drawing ink to wash out
B. was suposed to keep the liquid used to fill the screen under a light for several hours
Do you ever have issues with this?
Unfortunately you probably over exposed the screen or the image negative was not as opaque as you thought. Which would at best washing out the screen difficult at worst the screen its ruined and you either need to strip the emulsion and restart from the beginning or if really bad toss out the the screen (though keep the frame).
Usually using a soft tooth brush or scrub brush will help clear out those stubborn areas.
GraduallyGreener:
A. When applying the screen filler, how many times did you drag the squeegie across the screen? I try to do it as little as possible so that the screen filler doesn't start to fill in where the drawing fluid is, maybe 2-3 times across the design. You also may want to draw thicker lines with your drawing fluid, sometimes fine lines get filled in with the screen filler. Also, if you have trouble washing the drawing fluid out, I like to take a toothbrush and scrub the areas that aren't washing out (gently at first, then gradually applying more pressure as necessary). This always helps me..
B. I'm not sure what kind of screen filler you used. With Speedball screen filler, you don't have to expose to light...
Hope that helps! Let me know if you have more questions!
Thanks lots
You are the queen of this topic! Very helpful for making T-shirts for my meetup.com groups at an economical price. Thanks bunches.
Print it out.
Put the printout behind the mesh for step 3.
Another method you can use (that doesn't include screen-printing) is using iron-on transfer paper. You print your image onto the paper and then iron the paper onto your fabric, transferring the image. Check this out: www.ehow.co.uk/how_6099117_transfer-paper-fabric.html
If anyone else has another method, please share!
are you referring to the screen or the shirt? because they both hold up well to washing!
screen: can be used over & over, so long as you are using a fine material with very small holes. if the holes are too big, the screen filler will start to wash out after a couple of uses..
shirt: after you print your shirt, allow it to dry for a day or 2, then heat set the fabric by doing one of the following:
1) ironing on both sides of shirt for 3-5 min with a piece of fabric between iron & shirt (different ink brands may have different instructions)
2) throwing shirt into the dryer on high heat for atleast 10 min (I prefer this method, especially if you are making multiple shirts; ironing is very time consuming!)
3) adding a small amount of "fixative" to your ink (1-3% fixative) and you won't have to heat set your ink! i've never used this myself, but i've heard of this and am planning on trying it soon. Versatex makes this product: http://www.dharmatrading.com/products/vfix.html
