3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Screw Bowl - A Bowl Made From Screws
Do you have extra screws laying around your shop?
Would you like to have a very stylish bowl to impress your friends/family at parties or other social gatherings?
Are you bored?
If you answered yes to any of the above questions, this Instructable is for you.  Watch the video on Step 2 or read the more in-depth written instructions that follow it and you will soon know how to create your very own artistic bowl made from screws.  Show off your bowl at any get-together or just stare at it and bask in your own creative brilliance.
Step 1Supplies
The following supplies are necessary to make the Screw Bowl, although, as is always the case with Instructables, feel free to experiment.
Supplies:
  • Lots of Screws  I used 105 screws in my bowl that I had left over from a             building project.  If possible, use two or three (or more) types of screws, this gives the bowl a more interesting look.  I advice using galvanized screws if possible because their rougher texture lends itself to bonding with the glue better than regular screws.
  • Gorilla Super Glue (or hot glue for faster, but slightly less professional, results)
  • A Non-Screw Bowl the same size you wish the Screw Bowl to be
  • Aluminum Foil
  • Optional:  High Gloss, Clear-Coat Spray Finish (if you want the Screw Bowl to be shiny)
  • Optional (but recommended):  Acetone which will soften the Gorilla Super Glue in case you glue any of your body parts together or glue screws to your fingers
34 comments
Mar 16, 2012. 2:25 PMdziegler says:
What am I doing wrong? I'm using Gorilla Superglue, and it won't stick. I started with a tiny dab- didn't hold. Tried a tiny bit more, then more- no luck. I'm holing the screws in place for a minute- no luck. Can any one help me? I love this bowl and am determined to make it work. Thanks-
Nov 6, 2010. 5:29 PMGorillazMiko says:
Let's say I want to eat cereal..
May 29, 2011. 10:53 PMtaria says:
eat fast?
Oct 14, 2010. 2:07 PMMotaBoi says:
lol what can it hold?
Jan 13, 2011. 8:47 PMThur says:
Keys, wallet, whatever else might be in your pocket. It might be pretty cool for fruit, too.
Oct 15, 2010. 2:38 PMbackyardmunitionist says:
It appears to be functionally more like a basket than a bowl really.
Oct 12, 2010. 7:09 AMjnifrwebb says:
I'm gonna give this a try, hopefully this weekend.
Oct 11, 2010. 11:57 AMkrysteanuh says:
This is too cool. Definitely got my vote. ^_^
Oct 11, 2010. 7:00 AMbg_askins says:
I want to weld one together for a lamp shade
Oct 10, 2010. 11:19 PMSevaKaptur says:
Super idea!! Great!!
Oct 8, 2010. 5:47 AMKirbsome! says:
When I first saw this, I was totally going to make it.
But then I thought "ah, screw it"
(feel free to punch me in the face for such a horrible pun.)
Oct 10, 2010. 7:05 PMneijie says:
I love you....lol.
Oct 10, 2010. 5:43 AMrossjolliffe says:
Presents two by four... *WHACK*
Oct 10, 2010. 9:39 AMKirbsome! says:
Ouch.
Now I'm doesn't know the grammar.
Oct 7, 2010. 5:16 PMshaggs31 says:
Which glue is stronger, the super or hot?
Oct 10, 2010. 10:33 AMdacker says:
For this application, I suspect hot glue to be stronger, plus it's not affected by moisture.
The contact area between two screws stuck together is just a tiny dot, giving the superglue very little bonding area. The contact area for hot glue would be the same, but the molten glue would "wrap-around" the screws at the contact spot, giving a stronger bond. Essentially, fillets are formed at the bonds.
I would have to agree with the OP that using hot glue would be "less professional". In my experience, it's hard to dispense just a tiny dot of hot glue and I often have to deal with the wispy, spider web-like strands forming when pulling the gun away from the material.
Oct 10, 2010. 3:12 PMcodongolev says:
I'd use some five or ten minute epoxy. make just enough to do the bottom, use it, then make enough to do the sides. either that, or use very small amounts of one minute epoxy to do each screw individually.
Oct 10, 2010. 12:58 PMSuzanne in Orting says:
One way to deal with the wispies is to blow on them with hot air from a heat gun or blow dryer. The heat causes them to crinkle up like the legs of the Wicked Witch of the East after you drop a house on her.
Suzanne on Orting, WA
Oct 10, 2010. 12:42 PMhellstudios says:
Plus, the bowl would be a hell of alot more malleable with hot glue than with super glue.
Oct 7, 2010. 6:29 PMdanlab says:
if you get a good bond with super glue it will definitely be stronger plus you won't end up with blobs of glue all over.
Oct 8, 2010. 9:35 AMadbkwhitley says:
In the woodturning world, if it won't hold soup, it's art. So yeah, I guess this qualifies. Well done.
Oct 10, 2010. 10:59 AMMadrigorne says:
If it will hold fruit, or mail, it becomes a necessary office accessory. I will add this to the end of the mile long list of things I want to make...
Oct 10, 2010. 7:38 AMGreen Silver says:
Ha ha ha... Someone has a screw loose!
Oct 8, 2010. 3:02 AMle-Sid says:
is this dish-washer safe? ^_^
Oct 8, 2010. 3:59 PMArbitror says:
Well, It's iron. It also depends what finish you use.
Oct 7, 2010. 9:27 PMl8nite says:
"SCREWY IDEA" I like that and I like the whole concept. For those worried about the points you could always hit each screw on a grinder (lots of work) or use machine screws, in fact a whole set made from, wood and machine screws, nails and bolts would be real conversation pieces
Oct 7, 2010. 6:59 PMSkyfinity says:
SCREW THIS!
Anyway, that's pretty neat! I think it wouldn't hurt to put some felt on the bottom-most protrusions to keep your table safe, but otherwise a pretty... screwy... idea.
Oct 7, 2010. 6:40 PMcowscankill says:
I'm thinking awesome light fixture. Maybe even a sconce?
Oct 7, 2010. 5:50 PMTechNerd1012 says:
nice idea, looks cool
Oct 7, 2010. 5:36 PMsevenplymaple says:
cool..
but im concerned with the sharp edges. probably someone has an idea on how to eliminate that.
Oct 7, 2010. 5:39 PMmakerdan says:
A little bit of Sugru, perhaps? :)
Oct 7, 2010. 2:35 PMpeace, love, art says:
Just be careful not to scratch the surfaces it gets set on!
Oct 7, 2010. 1:07 PMmakerdan says:
How fragile is it? I mean, could it hold a few items without coming apart?
Oct 7, 2010. 10:29 AMrabidsquire2 says:
Can it hold all of my excess air filled baloons? Haha, just kidding. Neat Idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:Toglefritz
I am an undergraduate student at the University of Wisconsin - Madison. I am majoring in engineering mechanics and astronautics with a certificate in technical communication.
