Introduction: Screw Driver Holder
Picture of Screw Driver Holder
I had this really annoying problem. I had too many screw drivers, and they were all piling up everywhere and I could barely get around with all of them. I had a pegboard, with a couple of screwdriver holders, but it wasn't cutting it, I just didn't have enough. So, I came up with a solution. I figured out this super simple device that would hold all of my screwdrivers, and fix all of my problems... for now...
Step 1: Cut Your Wood
Picture of Cut Your Wood
This part is simple enough... just cut a length of wood to make the base out of. I used a 1x4 ish size piece of wood. and cut it until it was about a foot long.
Step 2: Laying Out Where the Holes Go
Picture of Laying Out Where the Holes Go
Now to lay out where the holes that the screw drivers go in are. I made two rows, evenly spaced apart, and then nine columns. I thought I was laying all of that out with a dry erase pen, but, as it turns out... it was permanent, so in the later steps, don't mind the lines on the wood permanently in my pictures, ideally, they would be gone.
Anyway, you want to set this up so that you will drill a hole wherever the lines you drew cross. At least that's the idea.
Step 3: Drilling
Picture of Drilling
After that, I set my wood in my vise, and started drilling. I used a 1/2 inch bit, but I wish I had a bigger bit, as some of my larger screw drivers just barely fit. After drilling all of the holes, I flipped the wood over, and then just cleaned it up a bit as there was some wood sticking out from drilling the holes, I just used a sander and a dremel with a sanding bit to clean that up.
Step 4: Attatching to the Wall
Picture of Attatching to the Wall
Now time to attach this to a wall. You could just drill some screws into it and then call it a day. But I had minimal wall space, so I drilled some smaller holes in the back, and then inserted some 12 gauge wire and twisted it to the wood. I then wrapped the wire around a hanger that I had had already on the wall. You might need to refer to the pictures to understand what I mean. After that, I drilled one screw into the wall in the corner of the wood as you can see in the last picture.
Now you can enjoy having an organized workspace with easily accessible screwdrivers, that don't get in your way every two seconds!!
russ_hensel made it! (author)2015-06-11
This from my wood/metal shop and in addition my not very popular instructable: Tell Phillips from Regular Tip Screwdrivers without Looking At The Tip
pucksurfer (author)russ_hensel2015-06-14
Sorry, but I thought of this myself. Although they are definitely similar, I thought of this on my own, without any inspiration from you Instructable or anyone else's projects. Though, is a basic idea so I find it unsurprising that 2 people came up with the same idea. I prefer to make my own ideas and build them, not necessarily copy others (but, I will still find inspiration in other's projects now and then)
About This Instructable
1,028views
27favorites
License:
Bio: I am a die hard Anaheim Ducks hockey fan. I love to take things apart and design/build innovative things and I am always thinking ... More »
More by pucksurfer:Multi-Use Bendy Phone Charging CableHow to Wax a Surfboard 2Inside the Engineer's notebook- A guide to pictorial sketches
Add instructable to:
