I was disappointed recently to find that there are no instructables on making wooden bowls with a scroll saw, even though there are lots of books published on the subject. So I've decided to fill the gap.
All you'll need is a scroll saw and a few other tools to get started. I like this project because it minimizes the amount of wasted wood (unlike bowls made with a lathe) and the bowls produced have very interesting designs. It's also surprisingly easy, as long as you have the patience to sand it to perfection... So let's get started!
I also wanted to thank my wife Trish, who inspired and helped me to tackle this project.
Remove these ads by
Signing UpStep 1: Materials
The following tools are mandatory:
These tools are optional, but make everything easier and improve the quality of the bowls:
- Table Saw
- Miter Saw
- Planer
- Jointer
- Drill Press with adjustable stage (For different angles)
- Belt/Disc Sander
- Digital Caliper/straight edge
- Wood glue
- Scroll saw blades (yes - they will break often)
- Pen/pencil
- Clamps, clamps, and more clamps
- Sand paper and sand paper belts for sanders
- Varnish (and/or stain, depending on what you want to do)
- At least 1 board foot of wood, can be pieces of various woods
Visit Our Store »
Go Pro Today »
Unfortunately I'm going on vacation next week so need to finish some bowls this week to be ready for christmas.
Good comments on using exotics for food. They can be pretty potent. Use domestic hardwoods if food is going to be stored in the bowl. Mineral oil is a fine finish and is food safe. So is Watco Danish Oil if you let it cure for about 2 weeks prior to use.
Jim
I like the wood used here , but I have none :( If I made this bowl with some scrap wood and stained it would it make a nice gift do you think?
And BTW, that bowl that you posted is really pretty, and it looks like you did a nice job matching up the stripes, which isn't easy.
Some people put it in the oven to get the purple back. Other people have had the experience where the color darkened after it was exposed to sun and air. I wonder if there's a difference between heartwood and sapwood and the way the cells react to cutting and sunlight, but have never seen a technical discussion of this.
Usually the advice is to keep the finished work out of the sun to preserve whatever color it has. I usually try to build enough contrast into my laminations and glue-ups to allow for color variation so any change isn't that critical.
Purpleheart sapwood is pinkish-cinnamon with a light brown streaks and is from 2 to 4 inches wide in mature trees. The heartwood is a dull brown color when freshly cut but oxidizes to a violet purple color when exposed to light. When exposed to sun and rain, the purple color will become black.
I'm sure you've seen/thought of something like this but making a jig where you drill a hole in the center of your rings, slide that through a dowel, and rotate about the center would give you a clean, consistent radius throughout the cut. Obviously the jig would need to be designed so you can change the placement of the jig dowel to change the cut radius.
I'm sure I'll be trying this in the future and if I do make up that jig I'll be sure to post it. Thanks for the guide!
On this, the inner circles are tight enough that they could be tricky, on a band saw.
