Scroll Sawed Wooden Bowls!
 by LMO
Featured
Step 5: Choosing bowl dimensions
The simplest way to make a bowl is to cut the rings at a 45 degree angle.  That way, the rings are as far apart as the laminate is thick (see picture below).  I recommend the diameter of the inner circle be at least 3".
If you want to try different dimensions to make unique bowls, grab a calculator or open up excel and follow the steps below (see second picture):
  1. Choose a diameter for the inner circle (should be 3-4")......D, cell A2
  2. Measure the maximum length/diameter of the laminate.....L, cell B2
  3. Measure the thickness of the laminate...................................T, cell C2
  4. Choose an angle to cut..............................................................(theta), cell D2
  5. Calculate width of each ring......................................................X, cell E2
  6. Cut and paste this formula into cell E2:           =TAN(RADIANS(D2))*C2
  7. Calculate the number of rings (round down).........................N, cell F2
  8. Cut and paste this formula into cell F2:           =FLOOR((B2-A2)/(2*E2),1)
  9. Calculate the final height of the bowl.......................................H, cell G2
  10. Cut and paste this formula into cell G2:          =(F2+1)*C2
  11. Play around with the cut angle (theta) until you are happy with the final height of the bowl.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
