Scrolling Led Based Time and Temperature Display
Published
Introduction: Scrolling Led Based Time and Temperature Display
The project is used to display real time clock and temperature on the Scrolling Led Display
Step 1: Component List
With Quantity
DC adaptar (5v 2 amp) × 1
DC socket × 1
P89V51RD2 controller IC × 1
40 pin IC base × 1
16 pin IC base × 3
Crystal 11.0592 Mhz × 1
Capacitor 33 pf × 1
Capacitor 1000 µF × 1
Capacitor 10 µF × 1
Tectile Switch (4 pin small) × 1
Resistance 10K ohm × 1
Resistance 100 ohm × 24
Connecting Wires × 10
General Purpose PCB (1 feet by 1/2 feet) × 1
5 mm LED: Red × 600
transistor BC547 × 47
IC 4017 × 3
Step 2: Matrix Formation
LEDs should be connected in the form of a matrix
the positive terminal should go the row
and the negative terminal should go in the column.
Step 3: Temperature Sensor and ADC
for calculating the temperature temperature sensor should be utilized and calculating its analog value analog to digital convertor is used. i am using ADC0809 for the circuit. if you have in built ADC in controller you can discard ADC and connect sensor output directly to microcontroller.
Step 4: Circuit Diagram
Step 5: RTC for Time Clock Output
DS1307 ic can be used for calculating the actual time for the circuit.
Step 6: Code
Embedded C
  • Clocks Contest
    Clocks Contest
  • Oil Contest
    Oil Contest
  • Make it Move Contest
2 Comments
Looks good from the pictures. Can u share more details esp of the matrix and the schematic used?
This looks really cool!
