Introduction: Scrumptious Seasonal Rapini Salad!
Picture of Scrumptious Seasonal Rapini Salad!
I had a bunch of fresh rapinis in the house & wanted to use it in a scrumptious seasonal salad. I also had a packet of haloumi that I needed to use up! Doesn’t it look just beautiful & inviting?
Step 1: Gather Your Ingredients!
Picture of Gather Your Ingredients!
Recipe: For 3 persons
Ingredients:
For the salad:
1 packet of haloumi, taken out of the package, water drained, dept dry on double kitchen paper on all sides
1 bunch of fresh rapine, cleaned, washed, spun dry, chopped into 2
1 ripe sharp crisp apple, peeled, cited & cut up into wedges
1/4 cup (40 gr) unskinned hazelnuts
For the apple cider dressing:
6 tablespoons of a fruity extra virgin olive oil
3 tablespoons of an unpasteurized organic apple cider vinegar
5 grins of finely milled black pepper
5 grins of finely milled pink salt
Step 2: Toast Hazelnuts. Make Dressing. Grill Haloumie Slices. Plate Up!
Picture of Toast Hazelnuts. Make Dressing. Grill Haloumie Slices. Plate Up!
Place a handful of chopped rapine onto 2 clean white plates. Arrange them just the way you like. Place 4 apple wedges all around the outside of the rapine on each plate.
Take a fitted non-stick pan & heat up on low heat. Place your unskinned hazelnuts in here & toast them for a few minutes. See that the hazelnuts don’t burn! Now, make the simple dressing. Take a jam pot & add all ingredients. Screw fitted lid on & shake the jam pot up & down & up & down again until all is evenly mixed. Taste. You must taste the lovely apple cider & it must have a punch! Yum!With a sharp knife, cut your haloumi into long wedges, like this picture. Brush them with a fruity evoo on one side & heat a grill pan onto high heat. When hot, place your cut up haloumi, smeared with olive oil on this side, on the long side, onto your hot grill & press them down a bit with help of a fork. Do the same with the other haloumi slices. Grill them on this side for about 3-4 minutes & oil the other side now. Then, carefully turn them over on the other side & grill them for a few minutes. Finally, plate up like photo above & drizzle a few drizzles of that fine dressing all over you salad but not over your grilled haloumi slices.
You can also find this tasty recipe here on my blog: https://sophiesfoodiefiles.wordpress.com/2016/11/12/scrumptious-seasonal-rapini-salad/
About This Instructable
105views
3favorites
License:
Bio: I am Sophie & have a foodblog: Sophie's Foodie Files! I cook mostly tasty healthy & colorful dishes with Sophie's twist! I also cook a ... More »
More by SophiesFoodieFiles:Iced Latte4-ingredient Green SmoothiesCourgette Ricotta Bake
Add instructable to:
