Sculpey Headphone Cord Organizer
16,231
201
29
Published
Introduction: Sculpey Headphone Cord Organizer
Organize your headphone cords with this simple sculpey solution
Step 1:
Supplies:
-premo sculpey  clay
-glass tray (one that you won't eat off of afterward)  or cookie sheet covered in aluminum foil
Step 2:
-Roll out the sculpey clay into a worm shape about 1/4 inch thick.
-Place on baking tray.
-Connect the ends to make an oval shape.
-Pinch in the center to create the shape above.
To bake:
-Set oven to 275 degrees fahrenheit
-Bake for 30 minutes per 1/4 inch
(check the baking instructions on your pack of clay)
Bake for 30 minutes
Step 3:
  • Pets Challenge
    Pets Challenge
  • Stick It! Contest
    Stick It! Contest
29 Comments
I like the number of people that take the time to tell you how your idea won't work without asking you how well it did for you or trying it on their own. Then there are the people that come on and try to say they have a better idea yet don't take the time to make an instructable, also nice. Anyway rant aside I like your idea. It looks like it could work and is cheap enough to give it a shot, well done.
i have another great way to stop your headpones from getting tangled. get some hama beads and cut them in half with nail scissors. snao them onto the headphone cord and continue this process until the entire headphone length is covered. the good thing about this is that you can choose the colours and colour patterns.
i think everyone's said this and i agree..i don't think super sculpey is the best material for this project..it seems like it would be likely to crack unless you took great care of it
also..I'm thinking maybe Sugru with an armateur wire at its core would work great
I tried this using LEGO tires and super glue... I have nothing better to work with.
Wow this is such a great idea for all my leftover sculpey clay! So much better then going out and buying one!
also, to make the finished piece sturdier I learned to put it in ice water for a minute or so immediately after removing it from the oven. :D
Good idea, similar to what I've been using for quite some time..... a rubber O-ring of about 50 mm in diameter and 2 mm thick.
Pretty awesome... I used to make all sorts of stuff from this clay, As far as i can remember, it doesnt give off any fumes, I used ot use our toaster oven and it was the one we made our food in too...lol I think youll be fine but, if you have an old toaster oven you can use, use it, its alot faster and less $$$ than heating up the big oven for a small item like this. You can also use the small oven to cure powder coated parts, as long as they are small enough to hang in it that is! lol But THAT WILL destroy your wife's new oven for sure!! lol
another thought, when it comes out of the toaster it may still be a bit flexible so try not to handle it untill its cooled off some so as not to mess it up any...lol
That's a good point.
man, I haven't seem sculpey in FOREVER! it's great stuff, I used to play with it all the time when I was a kid.
Brilliant instructable. I'm planning on trying this one, very, very soon.
great idea. does the polymer clay give off fumes while baking? My wife would kill me if that happened in her new oven. i might use an old toaster oven.
Polymer clay doesn't give off fumes, but it's always a good bet to use a dedicated toaster oven for polymer clay work. Wastes less energy. Doesn't make sense to heat up a whole oven just to bake a small piece of polymer sculpture.
See my comment above re: toaster ovens.
I learned the hard way that baking in a toaster oven is a bad idea--the temperatures are just too inaccurate. Instead, make a baking vessel for your PC: buy two matching disposable aluminum pie plates. When you're ready to cure your clay, place it in one pie plate and turn the other over it upside-down, as a lid, then, take a long strip of heavy-duty aluminum foil and crimp it tightly all the way around the join of the two plates. Bake the clay, as directed. Any fumes will be contained in the vessel.
Polymer Clay DOES give off toxic fumes if it starts to burn so monitor it (you can see the smoke) because though your oven says a certain temperature, it can actually be running higher or lower. Cooked properly, it will not harm you :)
I don't think polymer clay is a great product for this project, it has little/no flexibility so is highly likely to crack, chip or break with regular use, or if the cord gets snagged. Sorry. I like the shape, and it is a good idea, but I think Sugru would be more likely to stand up to use.
Actually, different types of PC are more or less structurally strong, and Premo Sculpey is one of the stronger ones--the best is Donna Kato Polyclay, though it's not as easy to find (online being your best bet). Also, preconditioning the clay is important to ensure a strong final product--that is, you need to roll and stretch it repeatedly, until it softens and is flexible. Finally, if you're concerned about flexibility, there is a flexible clay, but I say, Premo or Kato will do very well.
