Introduction: Sculpting Greenstuff Vehicle Scrolls!
This is a quick tutorial showing how to sculpt vehicle scrolls.
Step 1: Tools and Materials
You will need A tile or very smooth surface Vaseline Toothpick Knife Greenstuff
Step 2: Mix Up Some Greenstuff
Step 3: Roll
Roll out your greenstuff to about half the width of the scroll you want.
Step 4: Flatten and Smooth
Flatten and smooth the putty out as straight as you can.
Step 5: Cut
Cut out a section about the length of your little fingernail.
Step 6: In Half
Cut the section in half
Step 7: Cut More
Cut out a section one half longer than the other complete section
Step 8: Remove Excess Putty
Step 9: Line Em Up
Line up the two small sections parallel to each other.
Step 10: Overlay
Overlay with the larger section.
Step 11: Cut Out
Cut out a triangle on the smaller sections.
Step 12: Clean Up
Remove the unneeded greenstuff.
Step 13: Finishing Up
Finish up by rounding all corners and slightly curving the main part of the scroll and finally add some battle damage with the tooth pick.
