Sea Shell Mobile
2,626
33
Posted in OutsideBeach
Introduction: Sea Shell Mobile
About: I am a therapist and in my spare time, I like to bake and craft to de-stress. Check out the link to my cake website to see more of my work. I also have a blog: half-bakedart.tumblr.com
This is an easy way to display your shell collection
Step 1: Supplies
Supplies (A lizard snuck in the photo!):
- Shells
- Wooden Ring
- Hot glue gun
- Shell necklace or small shell beads
- Clear String (ex. fishing line)
- Hook
Step 2: Drill Holes in Top
Drill 8 holes in the wooden ring that will become the top of your mobile.
Step 3: Glue Shells to Top
Use hot glue to secure shells to the wooden ring (I covered both the top and bottom sides).  I filled in the gaps with small shells.  Leave  space around the drilled holes.
Step 4: Secure Hook
- Cut 8 long pieces of string.  4 pieces should be the length you want the mobile strings to be.  The remaining 4 should be longer to account for strings that will be attached to the hook.
- Tie the stings to the wood using the drilled holes and then secure with hot glue.  String small shell beads onto the top portion of the 4 extra-long pieces.  These strings should be tied both to the wood and to the hook at the top.  Glue shells around the drilled holes.
Step 5: Glue on Shells
Start at the top and string shell beads onto each string, then use hot glue to attach a larger shell.  Repeat this pattern all the way down each string.
Step 6: Hang
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
