loading
(This instructable will be almost entirely pictures so click on the pencil on them)The Seafox worked well in it's original configuration but it was underpowered using the Standard Bilge Pumps with the way I had them wired so I've decided to Retrofit it with some new upgrades. I could have just used thicker gauge power wires for the pumps and that would have made a vast improvement but I decided to upgrade the pumps to run propellers for optimal thrust.
I'm also going to be using the Seafox as a test bed to finalize my software and try out some new features I will be using on the new Rov I am designing. The main thing I wanted to test out was the Camera, Manipulator, and Auxiliary Lighting pivoting on the same mount, I also wanted to add a digital compass for navigation. I've also went into a little more detail of how I did things that were never shown on the original Seafox Pages. I do need to fix a few issues, I am still working on the lighting, and I need to fix some buoyancy issues with the Tether as the pipe insulation just doesn't work. I also plan on adding one more Vertical Thruster, because the boat propellers are not very efficient in reverse so surfacing is slow and there is not enough thrust to lift objects from the bottom.Everything else worked great in the few dives I have done so far. I still may add more detail as I get farther into testing but if there is anything you would like to know that I haven't shown yet just e-mail me and I will try to explain things. I find that images are better at teaching than words.
Step 1: The Frame
Step 2: The Robo Arm or Manipulator and Camera Assembaly
Step 3: Substep: Sealing It Up
Step 4: Another Substep: the Assembly for the Thing That Will Make the Arm Go Up and Down
Step 5: The Thrusters, Conversion to Propultion
Step 6: Thrusters, Fitting Them Onto the Frame and Stuff
Step 7: Making the Tether
Step 8: Substep: Making Floatation
Step 9: Seafox Control Box
Step 10: Navigation
Step 11: Lighting
<p>you got my votes!</p>
<p>it's NICE inventor</p>
<p>I have absolutely no way to use this right now, but I want it.</p>
<p>then how about you find a use for it like make it an amphibious vehicle be a minion to clean up your room, hell if i know you kould turn it into anything, you just have to have GRIT</p>
<p>Hi Stephen,</p><p>I think this is a really great project! I would like to suggest you break this down into more steps. Use 3-5 pictures max per step with some explanations about what the individual work step is about. That way you could increase your chances of getting featured by the editors and create more exposure for your project!</p><p>On a side note your username very closely resembles that of a popular YouTube channel and there might be some who would question this. Why not stick to Homebuild ROVs?</p><p>Cheers Alex</p>
<p>well :#1) I do not want to stick to rovs because it was kind of an assignment that I had and it was very hard, it was fun to do, but I wouldn't prefer to do it again</p><p>#2) as the name kind of states I was intending to do woodworking almost exclusively, this one was just something that I thought to share with the possibility of winning some stuff before I was late on in the project</p><p>#3)When I have the time and all of my homework is out of my hair I will be editing this instructable(assuming I remember)</p><p>#4) I WILL be publishing <u>many</u> more instructables when summer break hits, also ,any lathe workers out there might want to post tabs on this channel because I will be publishing an instructable on o homemade wood lathe steady rest for small spindles</p><p>#5)thank you for helping me with my first instructable!</p>
<p>sorry,when I in the text &quot;my website&quot; that was an autocorrection. I ment to say *this website*</p>
About This Instructable
2,506views
32favorites
License:
Bio: I am a person who cannot convert text to instructions very well so I have chosen to usually make my instructables entirely in the images ... More »
More by woodworking gentleman bear:Seafox ROV submersible retrofit
Add instructable to:
