Seashell Planter
236
9
Published
Introduction: Seashell Planter
About: Physicist, Serial Inventor and Social Entrepreneur. Mentor for the Google Summer of Code. Judge of StartUp Chile, StartUp Peru. Graduated from The Catholic University of Peru.
The Seashell planters are gorgeous with a succulent, cactus or air plant growing inside. Great for a sea themed rooms or just for some green inside. This eye pleasing planter will be sure to delight you with its fine details.
Step 1: Shell Preparation
Any seashell with a sizable shell that sits securely when its opening faces upward and an opening large enough for at least one plant (Succulent, Cacti or Air Plant) and deep enough to hold the soil mixture will work. Clean and disinfecting the shell before you plant prevents disease and fungus problems later.
Step 2: Filling the Shell
A thin layer of clean gravel provides drainage inside the shell. Covering the gravel with a thin layer of activated charcoal prevents any odors from forming in the standing water that may collect in this gravel layer. You can use the appropriate kind of potting soil mix or create your own. Fill it with a few plant cuttings.
Step 3: Maintenance
You would not need to drill holes underneath for draning. The key is to not over water, keeping your watering to a minimum and allow these plants to dry out completely between waterings.
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Spotless Contest
    Spotless Contest
3 Comments
I'm going to put a Tillandsia in one of these!
I dont know the scientific name but the common name is Nopalito
Fabulous! What kind of cactus is that?
