Seashell necklace by belsey
Featured
Step 3: Cure the sugru
Place the necklace on a 3D form so it hangs the way it would around your neck. The shells would stick out awkwardly if you let it cure on a flat surface. As you can see I used a pumpkin, but a ball would probably work too.
Curing Sugru 3mm thick takes about 24 hours. If the temperature is below 21°C (70°F) or if your piece is thicker it will take longer to cure.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
