3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Seat for a walker
Seat for a walker
I have a friend who has a disability. She tires easily and when she does she has a difficult time finding a place to sit when she needs it. I came up with this design that would be lightweight, removable, secure, could be hand washed, and would not be in the way when attached. The seat portion was recycled car seat harness from a child safety seat.
Step 1Gather tools and materials
In this instructable I used
sewing machine
scissors
seam ripper (not pictured)
Lighter
Materials
length of car seat harness webbing
1" flat nylon webbing
Heavy duty upholstry thread
4 1" welded steel D rings
8 1" welded steel O rings
4  3/4" electrical conduit claps (dipped in plastic dip prior to use)
To attach to walker I used
Pliers
flat headed screwdriver
8 comments
Feb 6, 2011. 9:31 AMreddnekk says:
Great idea. And--if you don't have a sewing machine, all straps can be riveted--riveter is cheap in handicraft store (Michael's, for example). And hammer can be used if no riveter available (altho you DO have to have rivets). Use at least four rivets per joint, space so they are not in line. And seat can be one piece of canvas with straps riveted along two opposite edges. (I don't have sewing machine, but DO have riveter.)
Now why didn't I think of this?
Feb 6, 2011. 11:27 PMQuestor says:
I like to use rivets and contact cement (two layers)
two layers contact cement
clamp then rivet
Feb 6, 2011. 8:39 AMjblessf says:
This is wonderful! It is light weight. Which makes it easier to use the walker. The ones that are sold in stores are too heavy. My hat is off to you.
Feb 6, 2011. 12:11 PMlaurel1 says:
I worry that the clamps would slip off of the handle and dump the person to the floor.
If the clamps were put on the side support bars, and could slide back and forth, the seat could be pushed back when the walker is folded. The blue straps, on the corners, could have INDUSTRIAL velcro to attach around the legs to keep the seat square when sat upon. I think that the clamps still should be used to provide extra strength.
Also, I don't know where to buy these, but there are wheels for the back legs that collapse so that the walker doesn't roll when someone sits on it. They sort of lift so that the weight is on the leg and not on the little wheel. These are usually on the walkers that have the flip seats. They have larger front wheels and these smaller collapsing wheels are on the back legs.
OK, grannie with a walker gave her two cents. I'll be interested to see how someone will improve on this. Oh, and don't forget to mention a weight limit so that a heavier person doesn't get hurt.
If anyone sees these collapsing wheels for sale anywhere, please let me know.
Feb 4, 2011. 12:11 AMJadagara says:
A great idea indeed. My wife has tumor on her spine and she now needs a walker to move around when she prefers that instead of on a wheelchair. Like your friend, she tires easily so a seat like this would be a relief during those moments. Thank you for sharing.
Feb 3, 2011. 7:31 PMjneul says:
Great idea. Simple, functional, relatively inexpensive
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:nneul
