Second Life for an Old PC Case Part I
 by balddemon
WARNING: This is my first instructable and I have not write in english for a very long time ,so my apologies for sintax errors and incorrect use of expressions. I expect to improve my english it will very usefull specially if I decide to make a second instructable.
Recently I bougth a new motherboard (Asrock G41M VS3 R2.0) it is a really tiny format and the case I was using at the time was big for it. I new I had somewhere an old PC case so I started to look for it and EUREKA, I found it covered whith dust, the front end was not its original one neither itscover. Anyway I decide to give it a second chance or I woud say a "second life" and make it suitable for the new board. Since I want a case a litle different from the common ones I also decide to customize it painting it whith a tribal design usually used for tatoos.
Tools: I used an angle grinder to make some cuts, files to work on the edges after cutting to smooth them , sand paper, spray paint, contact paper ( the sticky one that is used to put on coverbooks), an X-acto knife, the tribal design ( a wolf), masking tape, some paper and patience (I found that I need a lot of it when I begun to make the template to paint the tribal design).
Note: While making this instructable I experienced some trouble when I reached step 4, I  got an error message when updating, I tried to find out how to fix it, I updated my browser (Firefox) and the Java version but th results where the same I started again a new   tutorial but  I got the same error since in both tries I reached the 3rd step without  trouble I decide to split in two parts the instructable Part I  Intro and Steps 1 tru 3 and Part II Steps 4 and 5 with this note.
Step 1: Step 1: Some Cutting and filing
Since the modern motherboards has its connectors layout in a very different way than the old PC´s I had to make some cutting in the back end of the case frame, and also had to remove the grid that are used for the extension cards, here in this pictures you can see the marking of the cuts and the grid thas was removed
In order to smooth the edges and corners after I used the grinder for cutting I use a file to avoid hazarduos cutting edges
Computothought says: Jun 23, 2012. 3:01 PM
Cool so far...
balddemon (author) in reply to ComputothoughtJun 25, 2012. 10:09 AM
I published Part II there you can see the final result. Thanks
pfred2 says: Jun 23, 2012. 7:06 PM
Looks good!
balddemon (author) in reply to pfred2Jun 25, 2012. 10:08 AM
Thanks, Part II is already published
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
