It can be a great electronics class project or an microcontroller starter project. for your own use.
Remove these ads by
Signing UpStep 1Parts list
medium size breadboard......http://www.oomlout.co.uk/breadboard-830-point-p-250.html £5.11
LCD Display (16 x 2)...........................http://www.oomlout.co.uk/lcd-display-16-x-2-p-212.html £7.15
12 digit keypad...http://cgi.ebay.com/Electric-Keypad-12-Button-Keyboard-24VDC-20mA-Max-/110690838563?pt=LH_DefaultDomain_0&hash=item19c5b02823 .................................$9.99
4 buttons................................................................................................................$1.00-0
1 potentiometer.....................................................................................................$1.00-0
16x 500ohm, 4x 1k, 1x 6k resistors .................................................................$2.00-1
3 green LEDs.........................................................................................................$0.25-0
lots of jumpers or striped wires ........................................................................$1.00-0
And patients!!!!!!
tip: if u don't have any of this parts it is highly recommended you buy an arduino starter pack that will include almost every electronic part needed, like potentiometers, wires, leds and maybe an lcd. a good one, which i bought ,is http://www.oomlout.co.uk/starter-kit-for-arduino-ardx-p-183.html
As for the tools, a soldering iron and a wire striper and cutter should be enough.
i used your library and it worked just fine, it is extremely useful as when i change the power supply (usb /battery) the the values change. it has helped my a ton.
Although i will not update the instructable because i thing the use of libraries is quite more complicated than my suggestion least for a beginner.
thanx again and if u feel like so vote for me
I think the problem with your keypad reliability is because of contact bounce (also known as switch bounce) (http://en.wikipedia.org/wiki/Switch#Contact_bounce)
I recently updated my analog keypad backpack tutorial to include an Arduino library for use with an analog keypad. It has internal debounce logic so the return values from keypad.readKey() are reliable.
The library also accepts constructor arguments for the resistor values which allows it to calculate the co-responding analog voltage for each key reliably.
Check out step 7. I think it will solve your reliability problems.
L8r,
Dek
P.S.
There is a simpler example of debounce code in
Arduino File Menu -> Examples -> 2.Digital -> Debounce
