3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Secret Agent Earphones
Easy way to make FBI-escque earphones. This is very useful if you ever want to listen to music but also have one ear free (for instance while biking in the city)
Step 1Cut up an old phone cord
cut up an old phone cord
Cut the ends off an old springy phone cord.
get some earbud headphones, cut the earbuds off and cut the jack off.
you will need:
1 earbud
1 jack (stereo or mono)
1 cut phone cord
multimeter
soldering iron
88 comments
1-40 of 88next »
Jul 10, 2008. 1:12 AMwalamoonbeam says:
is there a DIY way to actually make an acoustic ear coil?
Dec 3, 2011. 4:06 AMraikut says:
i am also looking for an instructables for making an acoustic ear buds.
Jul 18, 2008. 4:30 AMrickfmdj says:
Phone wire is not good. I used hollow tubing only
Sep 6, 2009. 12:11 PMblaine1996 says:
why don't you just put one of the earphones in if you want to have one ear free? much simpler and doesn't require cutting anything, in fact it takes less effort than normal because you only have to put one earphone in
Oct 17, 2011. 3:14 PMafink4 says:
Come on man that wouldnt be cool then you have one of those lame white headphones now you have a FBI looking headphone
Oct 16, 2009. 3:40 PMfoxtrot4697 says:
but then, it won't be an FBI type headphone
Mar 29, 2010. 8:27 PMprodo123 says:
Earphones, you mean.
lol this reminds me of agents from Matrix
Aug 7, 2011. 6:05 AMmlincoln1 says:
like
May 19, 2011. 6:22 PMjpelletier1 says:
Why didn't you just took a stereo headset and only use one side? Or just cut of the other side if it border you that much? Seems much easier to me.
Jun 12, 2009. 6:22 PMcomputer_freak_8 says:
This is a neat idea. I think I'm going to have to try this one soon.
Jul 25, 2007. 12:04 PMzootboy says:
Just so you know, the tip of the stereo jack is the left ear and the ring is the right ear.
Nov 23, 2008. 10:30 AMCartermarquis says:
Right, just remember mnemonic for audio wiring: Red Right Ring. The Right channel is indicated by the Red wire(normally), and is the "Ring" of a Tip-Ring-Sleeve(TRS) connector. The left channel is the tip and the sleeve is ground.
May 26, 2008. 4:27 PMthemacg33k says:
(removed by author or community request)
Mar 6, 2008. 2:18 PMjaime9999 says:
Yes, which demonstrates a small flaw in this instructible. If plugged into a stereo source device, such as a walkman, ipod, or home stereo, don't build this using a Mono plug (don't follow the mono-plug wiring instructions). why? because a mono plug short-circuits one of the channels directly to ground (the plug barrel). Short circuiting a channel may damage some devices' amplifier circuits, depending on how they are designed. It certainly will waste energy. There is no (well, less) risk in tying two + signals together to feed a single load (the single speaker driver in the earbud). So, use a mono plug and follow the mono plug instructions only if you are using this with a mono device, like a walkie-talkie or AM transistor radio.
Apr 11, 2008. 6:54 PMDjProToJeeX says:
ive never heard of that being the case. and when i got my degree in studio production they showed us how to do things like this rewireing headphones and more with headphone jacks including turning headphones into microphones. So do you have anything to backup the statement of mono plug shorting circuits. Cause im interested in that, like some data or something. I say this cause that cant be true, they make mono/stereo switchable headsets. so if mono shorts stereo and stereo shorts mono. How can they get away with making switchable headsets. That was like a early 90s sales scheme and is nothing but myth. im an audiophile and have seen mono headphonos used in stereo jacks 100s of times on 100s of setups. So ima need to see a blown ipod or walkman or something.
Apr 14, 2008. 10:17 AMjaime9999 says:
A picture is worth a thousand words, so here are some sketches that illustrate the problem.
Photo 1 shows how a stereo plug mechanically connects. Terms: Plug=male, Jack=female. The shaft of the plug contacts the hole of the jack, establishing the ground (-) connection. The tip of the plug contacts a metal finger deep in the jack, establishing one of the channels' + connections. A portion of the plug's barrel near the tip touches another metal finger, less deep in the jack, establishing the other + channel connection.
Photo 2 shows how each half of the plug/jack mate and keep the two stereo channels separate.
Photo 3 shows how if you plug a mono plug into a stereo source, the full shaft of the mono plug (lacking that special separate barrel section) ends up shorting out the channels amp output that with a proper stereo plug would have carried that channel's circuit.
Apr 16, 2008. 2:21 PMDjProToJeeX says:
your illustration could use a little work as well
Apr 14, 2008. 1:46 PMjaime9999 says:
whoops, + and - are backwards in the above illustrations.
Apr 11, 2008. 8:00 PMDjProToJeeX says:
i just ran to best buy bought a cheap pair of mono/stereo switchable headphones took them apart. and theres no fancy capacitor or any fancy switch it just severs the connection between the left ear piece. all the difference in connector will really do is make for less distortion if any is caused by using one over the other. but mainly the real difference is well monaural and stereo.
Apr 14, 2008. 10:20 AMjaime9999 says:
Any headphone that can be stereo will employ a stereo (3-contact) plug, never a mono (2-contact) plug, so you are safe; no possibility of short-circuiting your amps (unless you specifically wire up a short circuit yourself).
Apr 14, 2008. 11:39 AMDjProToJeeX says:
thats a good drawing but still unless i see a broken walkman or ipod it doesnt ever happen and create a short. I can understand why they said it in the early 90s and how it was a sales scheme. but if it was true wouldnt there be a broken one somewhere and at least 1 post on the internet contributing to that fact. not just something saying it does happen. thats why i even went and bought a mono/stereo headphone set just to see if that claim is accurate AND ITS NOT. i been trying with a mono plug for 3 days to try and blow a jack or amp with no luck. as a matter of fact today is the second day we've tested this myth on a series of different players with a ATS-2, we tested signal-to-noise ratio, total harmonic distortion, frequency response, and milliwatt power output (tested multiple ohms of resistance including the standard 30 in dozens of scenarios). nothing no shorts ever nothing to infer that this is true. we were even tryd to create a short by putting mono plugs in half way and short of all the way. we even moded a mp4 player and tried to overload the jack with a mono headphone plugged in and still nothing. So if you got some fancy piece of equipment that can compare to the read outs i have from a ATS-2 that can show a short. Im going to have to say its just a myth with no hard facts its just theory.. and when i get back from lunch were going to keep on trying to blow a mp4 player or any devices amp with a mono plug. for as long as we have the lab for which is for another 5 hours so. after today there will be 18 hours put on trying to prove that concept with no luck. were waiting on another piece of equipment which is coming from another college in the area and hopefully we can get more data. cause this myth is going to be busted by days end.
Apr 14, 2008. 11:59 AMDjProToJeeX says:
we've also used for testing a series of audio precision meters starting with the ATS-2, and the 2700 audio analyzer and a Rohde & Schwarz FSU3 Spectrum Analyzer. and in 20 minutes were going to use a fsu3-k5-k7 setup to compile all of our data. cause all of us includeing a 20 year sound engineering proffessor believe this to be a load of bull and were going to put an end to it. if we cant get a one of a dozen ipods a modified ipod to have higher MW output. 4 walkmans, 2 computers with realtek ac97 onboard, and a dozen mp4 players from UXCELL.com which we have in class for a previous project on sound quality. so if one of these cant blow, nothing will. were also planning on testing stereo recievers a couple onkyos a few sonys, and some of those cheapo 2.0 sets you get from walmart or something that are like 80 dollars. were gonna leave recievers for tommorrow. and wensday where we will try to test at least 20 of them. at this point im going to be shocked if something actually blows. and if we get something to blow everyone of us includeing are proffessor will goto school for the entire day in pink tutu's and dance the nutcracker.
Apr 16, 2008. 2:19 PMDjProToJeeX says:
there never was any data that showed a constant short circuit. The only spikes we ever achieved were comparable to a stereo (3 contact) plug. and that was when audio was being out put and we were plugging and unplugging the headphones. but as i said at most times the spikes would be higher with a stereo plug then a mono (2 contact ) plug was in most applications. there never was any data that showed a short was ever occuring. If there was a short, then our data showed a stereo plug shorts a stereo jack all the while same as the mono plug. but in actuality are data shows there never is a short occuring in which is enuff to cause a short circuit that will "fry" a device if any. unfortunately im unable to participate with the group we have setup, today. As i fractured my jaw (mandibul) yesterday and need sleep for a week. OH THE PAIN being right never felt so painful.
Apr 27, 2008. 4:23 AMzootboy says:
Wow. Even I would never have gone to such lengths to prove I was right. Kudos to you, my friend.
Jun 12, 2009. 6:18 PMcomputer_freak_8 says:
Only one problem: It does cause a short!
I can almost guarantee you that all those stories are false. Anyone with even a little bit of electrical engineering experience will tell you that the best way to test for a short is to use a multimeter. I don't have a multimeter, so I did another test:
Construct a simple LED circuit. For the switch, use a stereo jack (female), and wire one side to the ring connector and the other side to the sleeve connector. When you insert a mono plug (male) into the jack, the LED comes on, because the sleeve on the mono plug shorts out the connectors of the stereo jack's ring and sleeve terminals.
Jul 4, 2009. 11:02 PMhoihoi151 says:
It doesn't short. all a mono plug does is merges the positive and negative signal into one path way. the same output of power is still present on the ground. but the audio is only channeling 1 signal. the reason the load wont short is because of the grounding. easiest way to explain is this.
Stereo. u turn 2 taps in the bathroom on half way. the sink drains the water easy.
Mono. u turn 1 tap on full. which = 2 taps on half. the sing still drains easy.
the ground or the sink hole always has the same load on it.
Jul 6, 2009. 8:41 AMcomputer_freak_8 says:
Yes, it does create a short. What you are referring to is true if both the plug and jack (male and female) connectors are mono. This conversation refers to a mono plug (male) with a stereo jack (female).
Jul 6, 2009. 3:07 PMhoihoi151 says:
ok stereo cable works like this TRS Tip is positive Ring is positive and Sleeve is Ground (negative) trust me it doesn't short
Jul 8, 2009. 7:43 PMdj_nme says:
On a stereo plug (or socket) the tip is the left channel, ring is the right channel and the sleeve is ground. On a mono plug there is no ring, the sleeve goes all the way up to the tip. So: if you plug a mono plug into a stereo socket, the sleeve on the plug will short-out between the ring contact and sleeve contact in the socket. If you don't believe this, go do it yourself and check continuity between ring and sleeve socket connections on a stereo socket with a mono plug inserted. The reality of the situation will then be instantly obvious.
Jul 8, 2009. 8:14 PMhoihoi151 says:
mate im an audio engineer. i know how the signal and power is divided. left and right channels both contain positive signals and the ground is the negative path. it doesnt short because instead of the postive being divided into 2 channels it is pushed into the one. but the load on the negative end is still the same. its still the same amount of power being distributed through the circuit. its like having small rivers flowing into 1 big river. (stereo). or 1 big river flowing into a big river (mono). i have put mono plugs into stereo ports all the time and it doesnt short.
Jul 9, 2009. 3:46 PMcomputer_freak_8 says:
Like I have already said: When you are using a (male) mono plug connected to the (female) mono jack, you are absolutely correct. However, that is not what this conversation is about.
You agree that with stereo, Tip/Ring/Sleeve == +Left/+Right/-Both, correct?
And you agree that with mono, it is Tip/Sleeve == +Both/-Both, correct?
Jul 9, 2009. 5:28 PMhoihoi151 says:
correct
Jun 24, 2009. 8:20 AMzootboy says:
First of all, this is an OLD discussion. over a year old. But anyway... Yes, using a mono plug in a stereo jack WILL short out the right channel. The ground on the mono plug will make contact with both ground (the sleeve in T-R-S) and the right channel pin (the ring in T-R-S). The question is, does it matter? And according to these people's testing, it doesn't. It appears that most devices have smart pre-amps that prevent a short from blowing itself out, or that a short will not blow it out anyway. But if you're really that concerned, just use a stereo plug! Simple as that.
Mar 8, 2008. 8:53 AMzootboy says:
well said. just remember to get the right type of jack when you buy it.
Oct 3, 2008. 2:16 PMPh3nomin0n says:
Ok I tried making this just like this instructable. but I ran into a problem... I am using a stereo plug btw. My Phone cord has 4 wires green,black,red, and yellow.. and on my plug I have red and copper, and green and copper. Obviously the red and the green go together but where do I connect the copper wires to.. Yellow? Black?
Sep 26, 2008. 9:05 AMPh3nomin0n says:
I did this slightly differently with same results and less soldering. I simply cut the plug off the earphone I was going to put in my ear and soldered it to a broken earphone wire that I had lying around thus making the earphone cable longer. Then I removed absolutely everything from the inside of the phone coil cable and stretched it out and inserted the cable through one end and out the other. A little more work but less work at the same time... but very nice instructable, nicely explained and everything... 5/5
1-40 of 88next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
