Introduction: Secret Arduino Voltmeter
A little known feature of many AVR chips is the ability to measure the internal analog voltage reference. This trick can be used in all sorts of ways such as:
For a more in-depth article, which includes calculation details, applications and calibration how-to, see Secret Arduino Voltmeter – Measure Battery Voltage.
- Monitoring battery voltage to your Arduino
- Checking to see if A/C power is running
- Improve accuracy of analogRead() in many situations
long readVcc() {
// Read 1.1V reference against AVcc
// set the reference to Vcc and the measurement to the internal 1.1V reference
#if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
ADMUX = _BV(MUX5) | _BV(MUX0) ;
#else
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Start conversion
while (bit_is_set(ADCSRA,ADSC)); // measuring
uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
uint8_t high = ADCH; // unlocks both
long result = (high<<8) | low;
result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
return result; // Vcc in millivolts
There are some limitations in accuracy due to tolerances on the internal voltage reference. You can however, calibrate the scale factor for greater accuracy. This code runs on all Arduino variants as well as the ATtinyx4 series chips.For a more in-depth article, which includes calculation details, applications and calibration how-to, see Secret Arduino Voltmeter – Measure Battery Voltage.
