3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Secret CD-drive stash
This Instructable will show you how to make your own secret CD-drive stash in which you can put your important CDs,DVDs or other flat objects.
Step 1What you need:
What you need:
To make your secret CD-drive stash you'll need:
-A CD drive (preferably one that you don't need anymore)
-A drill with a 5/32inch bit
-A screwdriver
-Soldering equipment
-Tape (preferably vinyl electrical tape)
-Clear, epoxy-like glue
-Wire (might not be necessary)
-Double-sided mounting tape
- A dremel or a saw
-A 4 AA battery holder
-4 AA batteries
-A pair of earphones (they'll act as a key to your stash)
16 comments
Aug 27, 2011. 9:47 AMpmn9393 says:
i do this all the time, but i use a paperclip in the manual eject hole, its much simpler, and i can reuse the drive if i ever need to
Jun 21, 2011. 10:12 AMmdog93 says:
If you leave the headphones in does that not just keep the button down and close it again? If not how do you get it to close.
It's a nice idea but i think it would have been easier to use the jack as the actualy switch. For example solder one wire to the ground contact (sleeve) and the other to either of the contacts (tip or ring) then providing the jack isn't a 'normally closed' jack with a sprung break contact when you plug in headphones the circuit is completed allowing the current to flow through the headphones and then throught the motor and so on.
Or would that not work?
Jun 22, 2011. 9:37 AMmdog93 says:
okay. I like it, i just wish the storage was the size of the drive, instead of only being that little flat space. Mybe if you took of the liitle tabs that hold the front cover on and glued the cover to the disc draw front then the whole front would come out when you pressed the button?
Jun 27, 2011. 6:42 AMmdog93 says:
yes you would have to lengthen the wires. Hardest part would be finding a way of keeping the draw etc. supported whilst gutting as much as pssible to make room.
Jun 20, 2011. 12:39 PMzack247 says:
a very unique idea to use headphones as the switch!
a further step to keep it more safe would be to use some sort of security screw that is hard to get open, like the screws nintendo used to use.
Jun 20, 2011. 1:45 PMac1D says:
The screw nintendo used to use could be open using a bic pen lol :-)
Jun 20, 2011. 3:48 PMzack247 says:
true but that was just an example.
theres also those triangle screws, i dont know of any way to get those out but messing around with a flathead screwdriver.
--on second thought it could be easier to just weld the case shut or something.
Jun 21, 2011. 1:37 AMac1D says:
Weld? Who doesn't have an dremel?
My point is just, any thing you do to protect it, we still will be able to take it.. it's why, I guess, he call this a secret stash, and not a safe ;-)
Jun 21, 2011. 6:29 AMzack247 says:
i suppose youve got a good point there.
but i think that this was done the way it was because no ones really going to think theres anything but cd drive inside a cd drive, unless theyve read this instructable, that is.
Jun 22, 2011. 12:08 AMac1D says:
after reading instructables, you can't really thing anything you see still has it's original fonction Lol :-)
Jun 20, 2011. 5:05 PMkelseymh says:
http://www.instructables.com/id/Screwdriver-with-triangular-head/
Jun 21, 2011. 8:22 PMLithium Rain says:
Awww, you're spamming my project! I didn't know you cared! :D
Jun 21, 2011. 9:26 PMkelseymh says:
:-D I don't think it's spam if someone else does it ;->
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Candymanproductions
