3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Secret Safe Thingy
Secret Safe Thingy
It's a really simple secret safe thing that only works for cash but hides discreetly and actually works and can be made again really easily
Step 1Materials
Materials
You Need:
A tissue box
A pair of Scissors
Mauly Clip (Binder Clip)
Cash
27 comments
Feb 17, 2011. 12:30 PMLouiseMarie says:
I'm with Joey2542667. OMG! i could just see someone throwing that box of money away. Or, giving it to someone saying, "No, that's ok, keep the box; we've got more." Sounds too risky for me.
Feb 16, 2011. 12:58 PMglorybe says:
As long as whatever you hide has no weight that tissue box should work if you live alone. You wouldn't want a family member borrowing your tissues.
One method that seems to trick most crooks is to take a bedroom door off of its hinges and drill a hole in the bottom of the door. Insert your stash and then plug the hole with the right sized,round ,wood plug. This is for longer term security as it does make retrieval a bit slow.
Another trick is to install a phony pipe. Some closets have exposed vent pipes and a phony pipe that enters the ceiling and has a cit out in the floors surface is very convincing. It should be plastic and not copper as crooks do take copper at times.
Dec 4, 2010. 10:03 AMstar_above_the_clouds says:
very cool! but you might want to try making the hole a little smaller, so the money has less of a chance of falling out.
May 31, 2008. 11:06 PMac1D says:
what if the tissue boc ran out of tissue?
Jul 9, 2010. 6:23 PMunmdec says:
when it gets low take out the money....i mean why rig a box that you can't monitor?
Jun 1, 2008. 9:33 AMDeltaforce2555 says:
What if the crook has the sniffles? He will make away with the cash and you will be out of a few tissues.
Jun 2, 2008. 8:24 AMDeltaforce2555 says:
Well what if he's really sick. And you come home there he is with five empty tissue boxes sitting on your couch watching the game show network asking you to make him some chicken noddle soup.
Jul 9, 2010. 6:22 PMunmdec says:
LMAO...i make him some soup with rat poison...
Jun 1, 2008. 5:30 AMmaruawe says:
Why not just put in a false bottom inside the box , Then even when the box was empty the money would still be safe and secure... I have lots of pictures 200 or more on my walls ( I do art work). You can cut a piece of canvas the same size as the inside of the frame , Then velcro the second piece of canvas to the inner rear frame you can hide money in between the canvas sheets. ps I use pictures with certain colors to make the deposit of cash so any picture with that color I know has money behind the picture
Oct 4, 2008. 3:29 PMjoey2542667 says:
yeah then when the tissues run out, someone goes and throws all that cash, beautiful cash, away.
Jun 16, 2009. 4:29 PMtannerr52 says:
(removed by author or community request)
Jun 17, 2009. 4:43 AMmaruawe says:
This has worked for over twenty years, and I have been robbed twice with out a loss from the pictures.. Of course there is a sign that states property protected by colts that may help deter the smarter ones..... proved true in 69 and 71.
Jul 9, 2010. 6:20 PMunmdec says:
colts? whats that?
Feb 1, 2010. 5:16 PMNinjaSloth says:
great idea, but what if someone throws it away?
Apr 6, 2009. 5:04 PMmas9779 says:
yes, thats a great place to hide "money"
Feb 28, 2009. 9:11 PMoniman7 says:
It's nice, but... given the choice, I would go with this :http://www.thinkgeek.com/gadgets/security/855d/
It's a safe that goes inside the wall, and looks like a regular power outlet. Here's what they say about it: "An easy way to conceal your stuff
The Hidden Wall Safe is handy because most burglars spend less than six minutes inside a victim’s home and only have time to check the most obvious places for valuables. These unique wall safes allow you to hide valuables inside one of many identical looking wall outlets you already have in your home, the last place someone is likely to look. According to the Chicago Police these units are better than a locked safe and a hundred times cheaper.
Worried about the outlet cover not matching your other outlets? No sweat, you can interchange any standard plug cover for this one to match your other plugs.
High impact plastic and metal
Once installed it pivots out to reveal the secret hiding place
Comes with cutout saw and template for easy installation in just minutes
Dimensions: 7"H x 3.5"W x 2.5"D
Jewelry and money not included!"
For $8, I think it's worth it.
Sep 28, 2008. 3:24 AMLilJay0131 says:
i wouldnt make the hole that big, and not a full square, u should make like a rectangle hole about the width of the clip and the length of the money (short way) the just slip it in so you can save and hide it and if someone moves the box they most likely wont feel the hole
Jun 9, 2008. 7:52 AMgrundisimo says:
I GIVE IT A 12.0. ;-)
Jun 3, 2008. 9:07 PMonlyonebowman says:
Thats a great hiding spot
5/5 stars
Jun 1, 2008. 2:42 PMGorillazMiko says:
Can I have some of that money?
+5/5 stars.
Woops. Accidentally put 4.5 stars. Sorry.
Jun 3, 2008. 8:11 PMmasterochicken says:
I find myself doing that often.
Jun 2, 2008. 11:46 AMschimmi says:
oooooooooooooo a new 5!
Jun 2, 2008. 12:07 AMexplosivemaker says:
i would stick it behind a frame or something instead......our tissue boxes always get knocked around....
Jun 1, 2008. 6:29 PMBlaminator says:
Ingenious, I got my 100$ bill origami stuff in mine, I rated u a 5!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lightpacker
