Secret Spy Shoe
Introduction: Secret Spy Shoe
Spy Challenge
First Prize in the
Spy Challenge
Secret Boot Heel Grappling Hook
1.  8" of 1/8" steel tubing
2.  10' of 1/16m or 3/32 steel cable
3.  1/16 or 3/32 wire clamps
4.  Old pair of shoes
1.  Drill
2.  Dremmel
3.  Welder (MIG, ARC, TIG)
4.  Wire cutters
Other helpful tools
1.  Torch
2.  Vise
Step 1: Cutting
Mark and cut the 1/8" steel tubing into two four-inch pieces.
Step 2: Bending
I found that the easiest way to bend the tubing was to put the metal in a vise and heat it up as hot as I could.  Then, I was able to bend it into a hook shape.  Do that with both pieces.
Using my MIG welder, I welded the two hooks together.
Step 3: Cutting
Taking the hook and one of the old shoes, I traced out the hook pattern on to the heel of the shoe.  After doing that, I put the shoe in my vice and drilled a 1/4" hole 3/4 of the way through the sole of the shoe.  This is the point where you begin to dremmel.  I dremmeled out a pattern in the shape of the hook into the heel of the shoe.  I then drilled a hole through the heel and into the inside of the shoe.  It is through this that the cable will go.  Once I had the hook well-embedded into the heel of the shoe, I had to glue a small magnet into the heel to secure it.
Step 4:
To store the cable, I decided to use an old sock and a piece of velcro.  I sewed a band of velcro on to the sock so that it formed a little velcro latch that holds the cable.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    Cute video. That must have been fun to make. But he forgot his gun when going overboard!
    i will have to make it!
    florman, you're probably safe, but please keep the following in mind:
    (1) Working Load Limits are for static (nonmoving) loads, not dynamic (moving) loads.
    If a cable breaks at 120 lbf (pound-force), a 95-lbf person jerking the cable at a rate of 40 ft/sec^2 would break the cable. [Calculation: 120 lbf * 32 ft/sec^2 / 95 lbf = 40 ft/sec^2]
    If a 95-lbf person were to swing on a 5-ft cable that breaks at 120 lbf, he would only have to swing 3 miles/hour (about walking speed) to break it. [Calculation: sqrt((120 lbf * 5 ft) / 32 ft/sec^2) ~ 4 ft/sec ~ 3 miles/hour]
    (2) Lucky for you, working loads are usually given a safety factor of 5, meaning that your cable shouldn't break until you give it a 600-lbf load. This means you (being 95 lbf) would have to jerk the cable at a rate of 202 ft/sec^2 to break it. You would also break it if you were to swing at about 6 miles/hour with 5 ft of cable.
    (3) Unfortunately for frisbeechampe1983's acquiantance, the combination of swinging and abrupt stopping when he hit the wall made a large enough acceleration for the load to exceed the cable's limit.
    (4) Additional notes: (a) Make sure you know the difference between mass and weight. (b) The working load limit is determined by a load being uniformly applied in a straight line pull. You are not only changing the load by moving along the cable, but any additional movement on your part makes it risky. (c) The tensile properties of the cable are changed every time you go on and off just because the loads are changing.
    Thanks I'l keep that in mind
    Where are you hiding the pillow you need to sit on after your mom caught you rapelling in your Sunday clothes?
    You could put a phone in your other shoe!
    Wait, I shouldn't give you any ideas.
    "This is Maxwell Smart, secret agent 86, calling for Control! Come in, Control!"
    Hey mate, nice instructable, but I wouldn't recommend it on the way you use it...
    The cable is very thin and you cannot hold it very well for a slow rappel... Probably another use. But GREAT idea
