Introduction: Secret to a Flaky Pie Crust
Picture of Secret to a Flaky Pie Crust
A flaky pie crust doesn't have to be intimidating . . .
Step 1: Ingredients:
Picture of Ingredients:
1 cup All Purpose Flour
½ cup Shortening
½ tsp. Salt
4 Tbs. Ice Water
Step 2:
Picture of
Combine flour and salt in a bowl and mix.
Mix in shortening with fingers until combined and crumbly.
Add ice water until just combined (do not over mix).
Step 3:
Picture of
Roll out on a floured cloth with a sleeve on your rolling pin (cover your sleeve with flour too).
Step 4:
Picture of
Put pie crust into pie pan.
Step 5:
Picture of
Work as much of the crust into the pan as you can (this prevents it from shrinking while baking).
Step 6:
Picture of
Cut off any excess around the edge, fold under and make decorative edge of your choice.
Step 7:
Picture of
And now the secret to a flaky pie crust . . . with a fork poke holes and I mean poke a LOT of holes.
Step 8:
Picture of
Don’t forget to go up the sides.
Step 9:
Picture of
If you just need a cooked crust, bake at 425 degrees for 14 – 16 minutes until golden brown.
Step 10:
Picture of
If you are making a cooked pie, put your crust in the oven (425 degrees) and bake until it becomes dull (watch closely).
Step 11:
Picture of
Fill your crust with your filling, lower the temperature to whatever your recipe calls for and continue to cook as instructed.
JohnMPIII (author)2017-01-07
Can I get the same flakey results using butter in place of shortening?
BobbiLP (author)JohnMPIII2017-01-07
Yes, just make sure your butter is cold.
Augustny (author)2017-01-02
Thank you
Hello,
Wandering what iced water adds to the crust?
Like adding iced water vs lukewarm water difference.
Thank you
BobbiLP (author)Augustny2017-01-02
The ice water keeps the fat from melting which makes a flakier crust.
fred3655 (author)2016-12-22
Is this good for quiche also?
BobbiLP made it! (author)fred36552016-12-22
Absolutely! I do the little pre-bake until the crust looks dull and then pour my quiche ingredients in and finish baking. It's also good for chicken pot pies (I just use it on top)
Swansong (author)2016-12-21
Looks delicious :)
BobbiLP (author)Swansong2016-12-22
Thank you!
connie46 (author)2016-12-22
will this keep the crust from becoming soggy ?
BobbiLP (author)connie462016-12-22
I think pre cooking the crust a little bit does help to prevent it from becoming soggy, I've never had a soggy one.
About This Instructable
2,768views
64favorites
License:
More by BobbiLP:Secret to a Flaky Pie Crust
Add instructable to:
