Securing a Raspberry Pi Web Server
2,383
43
Posted in TechnologyRaspberry-pi
Introduction: Securing a Raspberry Pi Web Server
Team members: Snehpal Singh, Rohan Kapadia, Mandar Pednakar, Prathamesh Timse
First, we hardware configure the Raspberry Pi using the manual and by running the boot, making desired changes and setting up the password.
Now, we make the Raspberry Pi our webserver we use the following code:
First, we are going to update the clock, update our sources, then upgrade any pre-installed packages. Type the following at the command line (press return/enter after each line):
sudo dpkg-reconfigure tzdata
sudo apt-get update
sudo apt-get upgrade
Next, we want to install Hexxeh's RPI update tool to help keep Raspberry Pi up to date. To do this, run the following commands (press return/enter after each line):
sudo apt-get install ca-certificates
sudo apt-get install git-core
sudo wget https://raw.github.com/Hexxeh/rpi-update/master/r... -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
sudo rpi-update
sudo shutdown -r now
sudo apt-get install apache2 php5 libapache2-mod-php5
sudo service apache2 restart
sudo apt-get install mysql-server mysql-client php5-mysql
sudo chown -R pi /var/www
sudo apt-get install vsftpd
sudo nano /etc/vsftpd.conf
anonymous_enable=YES to anonymous_enable=NO. Uncomment local_enable=YES and write_enable=YES. go to the bottom of the file and add force_dot_files=YES.
sudo service vsftpd restart
Now, we set up iptables rule to prevent against common DoS attacks using following code:
# Reject spoofed packets
iptables -A INPUT -s 10.0.0.0/8 -j DROP
iptables -A INPUT -s 169.254.0.0/16 -j DROP
iptables -A INPUT -s 172.16.0.0/12 -j DROP
iptables -A INPUT -s 127.0.0.0/8 -j DROP
iptables -A INPUT -s 224.0.0.0/4 -j DROP
iptables -A INPUT -d 224.0.0.0/4 -j DROP
iptables -A INPUT -s 240.0.0.0/5 -j DROP
iptables -A INPUT -d 240.0.0.0/5 -j DROP
iptables -A INPUT -s 0.0.0.0/8 -j DROP
iptables -A INPUT -d 0.0.0.0/8 -j DROP
iptables -A INPUT -d 239.255.255.0/24 -j DROP
iptables -A INPUT -d 255.255.255.255 -j DROP
# Stop smurf attacks
iptables -A INPUT -p icmp -m icmp --icmp-type address-mask-request -j DROP
iptables -A INPUT -p icmp -m icmp --icmp-type timestamp-request -j DROP
iptables -A INPUT -p icmp -m icmp -j DROP
# Drop all invalid packets
iptables -A INPUT -m state --state INVALID -j DROP
iptables -A FORWARD -m state --state INVALID -j DROP iptables -A OUTPUT -m state --state INVALID -j DROP
# Drop excessive RST packets to avoid smurf attacks
iptables -A INPUT -p tcp -m tcp --tcp-flags RST RST -m limit --limit 2/second --limit-burst 2 -j ACCEPT
# Attempt to block portscans
# Anyone who tried to portscan us is locked out for an entire day.
iptables -A INPUT -m recent --name portscan --rcheck --seconds 86400 -j DROP
iptables -A FORWARD -m recent --name portscan --rcheck --seconds 86400 -j DROP
# Once the day has passed, remove them from the portscan list
iptables -A INPUT -m recent --name portscan --remove
iptables -A FORWARD -m recent --name portscan --remove
# These rules add scanners to the portscan list, and log the attempt.
iptables -A INPUT -p tcp -m tcp --dport 139 -m recent --name portscan --set -j LOG --log-prefix "Portscan:"
iptables -A INPUT -p tcp -m tcp --dport 139 -m recent --name portscan --set -j DROP
iptables -A FORWARD -p tcp -m tcp --dport 139 -m recent --name portscan --set -j LOG --log-prefix "Portscan:" iptables -A FORWARD -p tcp -m tcp --dport 139 -m recent --name portscan --set -j DROP
Now, we set up scripts for advanced firewall protection and brute force attacks:
wget http://rfxnetworks.com/downloads/apf-current.tar....
# tar xfz apf-current.tar.gz
# cd apf-*
# ./install.sh
Run it using:
# apf --start
BFD:
wget http://rfxnetworks.com/downloads/bfd-current.tar....
# tar xfz bfd-current.tar.gz
# cd bfd-*
# ./install.sh
Run it using:
/usr/local/sbin/bfd -s
Now the webserver is secure against basic DDoS attacks and have advanced firewall protection.
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
