Security System
1,437
23
5
Posted
Introduction: Security System
Maker name : Shivaraju. R
Materials:
  1. 9v battery
  2. Buzzer
  3. Wire
  4. 9v battery clip
  5. Card board piece
  6. Cloth clip
  7. Nylon locking wire
  8. Small aluminum piece
Tools:
  1. Glue gun
  2. Soldering gun
  3. Nile
  4. knife
Step 1: Take All Components
Take a all components, first you should cut the card board in require size (one piece should be big and remaining one should be very small ) a shown in the image.
Step 2: Solder the Buzzeer
Take a buzzer and wire after that solder the two wire as shown in the image.
Step 3: Make a Hole in Aliminum Piece
Take a two small aluminum piece make a hole with the help of the Nile after that connect the wire and fold it.
Step 4: Connect the Aluminum Piece on the Cloth Clip
Connect the aluminum piece in between the cloth clip in both in side the ends as shown in the image.
Step 5: Take a One Cardboard
Take one small cardboard and make hole after that tie it with the help of nylon lock wire.
Step 6: Fix the All Components
Fix the all component on the big cardboard piece by using hot-glue gun after that put the small cardboard piece in between cloth clip as shown in the image.
Step 7: Your Prject Is Ready
So however your cheapest security system is ready to use.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
5 Comments
You can simply use a "reed switch door". It's cheaper, about 1$ and looks well.
For example: http://goo.gl/N2pI7j
This is mind work not about buying and stuff.
I like the simplicity of this. Of course you can make several of these for different "security zones" and wire them all in parallel with just the one 9v battery all on a single piece of cardboard. Putting an led and resistor across each buzzer would allow you to see which zone is alarming and which is not alarming in the dark. Good project.
Thanks for your idea, and i will try to make it batter.
Its really Cool and cheap security system.
Thank you for sharing
