If you want to see more check out my blogmy blog
Remove these ads by
Signing UpStep 1: Assemble Your Supplies
Once I was done eating this particular citrus I saved the seeds and soaked them for a day or so in a glass of water.
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
this isn't really about growing trees. It's about a method of seed starting, I just used the seeds from a citrus to illustrate how it's done. But now that I see the title I can see why you would think that. I'll edit it.
why should YOU be able to grow the best tree for free, after somone worked for years to achieve it's properties?
Well either the seeds will result in an inferior plant because of hybridizing and or grafting that will be nothing like the parent(s)or I'm ripping off the work of some scientist. You can't have it both ways.
BTW if you are so bothered by people getting something "for free" off of the work of others is this really the best website for you? Just about everything here is based off of something else that someone created after a lot of work.
