3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Seed starter greenhouse made from on hand materials
My last greenhouse was overcome with mold, so to prevent giveing the mold a place to live I ended up throwing it out. However I wanted to start new seeds soon and I am working on a limited budget so making a trip to the local hydroponics store was out of the question. I was able to make a new one with materials on hand in the true diy style
Step 1Pick your victims and get started...
I started with an old pan that I couldnt stand to use to eat off of but didnt want to throw away just for some reason like this.
http://static2.instructables.com/pub/FBX/DO14/FBXDO1481AEXCFFJ9A.medium.jpg
22 comments
Apr 15, 2009. 1:27 PMstefannasehi says:
do u need it completly sealed? i thought plants need to have co2 to live. this would cut off the supply of co2, suffocating the plant right?
Jan 2, 2012. 6:00 PMdoomsayer_md says:
plants breathe both oxygen and Co2 and they also give off both oxygen and Co2. however it would be a bad idea to to completely seal the container as it would encourage mold. you generally want a very small air vent to allow a bit of moisture to escape
Apr 15, 2010. 9:41 PMahmad2117 says:
I made one but it was very small and not as good as yours but great idea
Mar 9, 2009. 1:41 AMmarancat says:
I like your idea of using pop bottles for the supports. I have done similar things with sticks but they poke thro the plastic. Your idea is much better. Thanks.
Jun 27, 2008. 2:00 AMsissysissysissysii says:
your idea is greatT Thx
Jun 3, 2008. 3:37 PMcowscankill says:
sweet. gotta do this for my bean.
Nov 14, 2007. 8:41 PMpyroswmr says:
hey as far as the green color goes, studies have shown that green colored light actually is detremental to plants. I don't think it will matter too much in this case, because the bags are rather transparent, and the plants are just starting from seed. the reason green light can kill plants is actually quite interesting. see, plants look green to us because they reflect the green part of white light (ROYGBIV) so in effect, when only exposed to green light, the plants theoretically are reflecting the light of this wavelength, and are basically not absorbing any light at all. unfiltered sunlight is best, but I read somewhere that UV filtered sunlight works even better, and pure red light is a close second to natural light.. ..or something like that.. anywho, I don't really think it will matter much in this case because the plants are starting from seed, and aren't really relying on sunlight until the main leaves start to grow.. aye!
Jun 2, 2008. 3:36 PMDzakovich000 says:
Absolutely, I was going to mention why most plants are green but you beat me to it. The fact that he is using a green colored plastic is helpful because it will help reflect a lot of the green frequencies of light before they reach the green plant leaves. I wonder, though, if he used a really green plastic cover if the plants would over time turn a different color....
Feb 20, 2008. 5:06 PMThe Saminator says:
nice instructable. good job.
Jan 25, 2007. 8:51 PMGthing 2.0 says:
looks amzing dose it stink up the place?
Jan 25, 2007. 11:14 PMGthing 2.0 says:
THANKS FOR LETTING ME NOW BEFOR HAND SEE IF U CAN CHECK OUT THE VALINTINE PROJECT "U LIGHT UP MY HEART"
Oct 22, 2007. 6:18 PMtippmannphreak says:
WHY ARE WE YELLING?!?!?!
Aug 29, 2007. 1:45 AMDanDaDad says:
Something Ive been doing for years is using half of an egg carton. Fill the egg holders with soil, put your seeds in, cover with plastic wrap, set in on the window ledge, or better yet, on the top of your fridge if you can. The heat from the fridge appears to boost the seed growth some.
Aug 2, 2007. 10:59 AMstarwings says:
Hi, No need to make it absolutely air tight. Plants in a greenhouse need some airflow. Cotton balls are supposed to make a nice cheap easy on hand starter media as well thats supposed to be somewhat mold/damping off resistant. Get some cotton balls (could use a tampon or pieces of sponge) spritz or wet otherwise, place a seed or 3 in the ball and place in the greenhouse. Don't let the balls dry out. The ball shouldn't be absolutely dripping wet. Nice job on the instructable and cool idea. Thanks for posting it. gentle day.
Feb 2, 2007. 5:40 PMPunkguyta says:
Would this work good for growing pot?
Mar 16, 2007. 6:54 PMDucky_2010 says:
And only if you want to get arrested. You're better off buying from somebody then getting busted for growing.
Mar 22, 2007. 1:34 PMPunkguyta says:
Ah, of course, but in my case, I live in a small town and well, weed doesn't happen to be a commodity around here.
Mar 13, 2007. 12:59 PMzus says:
For starting it yes but not growing it full out
Mar 22, 2007. 1:35 PMPunkguyta says:
Well when growing, it's important to make sure it "starts" out well and then after that when they're adult plants they aren't as sensitive to changes in the humidity/heat
Feb 25, 2008. 1:43 PMhomebowyerboy says:
you do realize the gov can track i.p. addresses right? your just setting yourself up to wreck your life doing drugs to begin with, and now setting yourself up to get busted.
Feb 28, 2008. 5:21 PMPunkguyta says:
Lolz..Not gonna happen. My ip address shows up as a town's address that happens to be 100+km away, and cycles to different towns daily, but not to where I am. My isp's setup is just coincidentally handy.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Meico
I am a college student without a college. I plan to major in Computer Engineering. But for the moment I am takeing my time learning and enjoying life. My current intrests include Computers, electronic...
more »
