iImage Information
If you've ever had a Sega Dreamcast, you know how awesome of a console it was. I love the dreamcast, but I got rid of the TV in my bedroom. Crap. What was I ever to do? Why, hack it open of course! Oh, sure, I could just as easily go out and buy Sega's "VGA box" for about $30 This mod will tell you how (assuming you have some decent soldering skills) to add a vga port to the back of your Dreamcast, for considerably less than the cost of a commercial VGA box which does the exact same thing. No IC's are involved here, just regular components, like capacitors, resistors and diodes. I plugged my Dreamcast into my LCD monitor, and it works like a charm.
Tools Needed:
No. 2 Phillips screwdriver
Wire cutters/strippers
Soldering iron
Dremel + cutting bit (steel bur or cutting wheel works well)
Materials Needed:
3x 220uF capacitors
2x Silicon diodes
2x 4.7Kohm resistors
2x 150ohm resistors
1x Slide or toggle switch
1x Female VGA port
1x 3.5mm stereo audio jack
Solder
Electrical tape
Step 1Removal of the top cover.
iImage Information
Remove the four screws on the underside of the dreamcast. There will be one in each corner. If you have a modem for your Dreamcast, remove it to expose the 4th screw.
Flip the whole thing right-side up and take off the top panel. Make sure you didn't leave a disc in the drive (I made that mistake several times while troubleshooting).
The connector schematics are very useful.
Other than that, awesome write up. I should really do this, being as I will usually play my dreamcast on a pc monitor, which you have to do because once you start using the VGA output, you can't go back to standard signal again.
Great ~_~
unfortunately I don't have access to an oscilloscope, but I allready solved the Problem! It's because the RGB/AV Switch. I soldered the Cables wrong. I soldered it like this: Position 1: VGA with GND, Position 2: RGB with GND, but when you look @ the schematic, VGA AND RGB must be grounded mit GND!
Now it just works fine ^_^
Jack
http://assemblergames.com/forums/showthread.php?t=21585
http://www.raphnet.net/electronique/dreamcast/images/dricas.gif
Its talking about an IC 74HCT244.
Its dangerous if I don´t use it like in your mod?
Thanks
More information about the chip itself is available here: http://en.wikipedia.org/wiki/PowerVR.
