Step 6Let's go over the circuit...
Anyway, as for the capacitors, the negative side should go towards the VGA connector. All of the pins on the VGA connector marked with a black dot must be grounded. The ones with white dots are unused.
By the way, if you want to add an audio jack, just use pins 2 and 3 and wire that to the right and left terminals on the jack. Ground the ground pin on the jack. I can't tell you, by the way, which one's left and which one's right, so you have a 50/50 chance of getting it right. My stereo's messed, so I can't tell you whether I picked the right one.
Do yourself a favour and don't try to solder on the top of the board. Flip it over, and you'll see some solder dots that are spaced further apart. (It's like Sega made the Dreamcast easy to hack on purpose)
The pinouts and their corresponding numbers are the same on both diagrams.
The connector schematics are very useful.
