3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Segmented Salad Bowl Maple and Walnut
Hello everyone,  this is my 12th bowl that I have "successfully" completed and my 2nd segmented bowl.
I made it for my Fathers nurse for a Christmas present. Im am pretty proud of this one as it is the finest piece I have made thus far.
This one was a lot of fun. enjoy.
Lathes are very dangerous and you can become seriously injured or even killed operating one. I have a lot of experience and knowledge you should only attempt this project if you have sufficient knowledge, experience and safety gear.
Step 1Lumber selection and preperation.
You can make this out of any type of wood you choose, though I would suggest using hardwoods.
I chose some Harvested Maple from a friend and some Black walnut I brought from eastern Tennessee.
These two woods accent each other wonderfully.
I didn't measure anything except the bowls finish dimension. also take into account your lathe "swing" allowance, My Delta 46-460 has a 12 1/2" swing. so I chose to make the bowl around 11 1/2 - 12" in diameter.
The bowl consists of a solid walnut base with progressively larger "rings" of segmented octagonal circles stacked on top of one-another for a grand total of 5 rings of 8 segments each each segment is cut at 22.5° at each end. each set of segments per ring must be the same length
after choosing the lumber you need to rip it into strips. I chose 1 1/2" widths but looking back I coulkd have gone less.
once you have enough lumber ripped for your bowl (you have to do the math) cut all of your segment for the bowl one ring at a time. this will ensure you have the same sized segments for each ring.
28 comments
Jan 29, 2012. 9:48 AMquiltina2 says:
Absolutely beautiful bowl !!!!
Jan 3, 2012. 4:21 PMPenolopy Bulnick says:
That is just amazing! You have done a wonderful job!
Jan 3, 2012. 9:56 AMCarleyy says:
Beautiful!
Dec 29, 2011. 7:02 AMtvm777 says:
what did you add for finish? or you make it?
for me its easy to get beeswax, but mineral oil? like? Linseed oil can be good finish also?
Dec 30, 2011. 2:15 PMSwampcreature says:
If using linseed oil, you should read the label carefully because some linseed oil furniture finishes have lead and/or other toxic materials added as preservatives. Mineral oil would probably be a better bet for use in a food-safe finish.
Dec 29, 2011. 8:21 AMtvm777 says:
that was my question, extra of what?
so u mixed linseed oil and bees wax?
Dec 29, 2011. 9:15 AMtvm777 says:
thanks! :D
Dec 27, 2011. 10:30 PMskiedra says:
Absolutely beautifull!
Dec 29, 2011. 7:51 PMWheatridge says:
Slick Squeegee, that was a great project. You did good. Segmented turning is a most rewarding endeavor. Keep at it. There are many directions to take.
Dec 29, 2011. 6:45 AMbillyup says:
Most of my pro woodturning instructors, demonstraters, and finish books/DVD, etc, say that all un-leaded finnish are food safe-ONCE THEY HAVE CURED. It can take various times to realy cure, depending on what you apply. Some say that mineral oil never cures, and can retain impurities. ???? Maybe the varnish based oils would work, as they do cure, but takes a longer wait.
Dec 29, 2011. 9:52 AMbillyup says:
I never use Poly, not only for the reasons you cite, but also one can't repair a ding, scrape, or water damage. I use EEE, Black Bison, Shellawax some, but most finish is CAB Acrylic Lacquer on larger pieces. On smaller quick project I use Rust Oleum or Deft, clear Lac spray can, as I find Minwax spray inferior.
Not had a problem, unless one fills a bowl with water and lets it sit.
I suppose I should go back and study Bob Flexner some more, as I am always willing to learn.
Billy
Dec 29, 2011. 5:40 AMaristide202 says:
Good chice of woods, nice design and nice result. Congrtulations
Dec 28, 2011. 10:34 AMLucas.Worley says:
Very nice piece, nice joints. I enjoy doing segmented work, i just completed a segmented vessel for my brother, I'll post a pic.
Dec 28, 2011. 11:50 AMyokozuna says:
Sweet, when is your instructable forthcoming? :)
Dec 28, 2011. 3:13 PMLucas.Worley says:
Well i didn't think to take any pictures until the end, so I'll make an instrucable on the next one I make.
Dec 28, 2011. 8:41 AMrimar2000 says:
As I said before, these bowls are very beautiful.
What I think is quite difficult to cut sectors exactly to 23.5 ° to form a perfect octagon. Does that prove and error?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:SlickSqueegie(MDWoodart)
If you like my projects please rate and subscribe. Lots more Instructables to come!
