Introduction: Selection Guide of Conductive Thread for Machine Sewing
Picture of Selection Guide of Conductive Thread for Machine Sewing
  • In this article, we describe conductive threads suitable for machine sewing (e-Textile)
Term of use
This article is provided by Brother Industries, LTD (“Brother”) under terms and conditions of Creative Commons Attribution-ShareAlike (“CC-BY-SA”).
Users may use, copy, alter, or distribute any of the contents included herein, provided that, a) all terms and conditions included in CC-BY-SA and all legal provisions of “Instructables” (including, but not limited to, Terms of Service and Privacy Statement included therein) shall apply and Users shall be legally bound by them, and b) Brother shall not be responsible for any damages incurred to Users by following or reffering any instructions or guidances posted in this article or otherwise using, copying or distributing any contents (in ASIS or in modified style or manner) of this article. Brother disclaims any and all warranties that the contents of this article is safe, useful, harmless, academic, or have any possibility of merchandice, and Users shall use, copy, alter, or distribute the contents by its sole risk and discretion.
Step 1: What's Conductive Thread
Conductive thread was originally developed for industrial use such as heat resistance material. These day, it is used for e-Textile or wearable computing due to it's electrical conductivity. It can make "sewn circuit" by connecting micro-computer, LED, touch sensor, etc.
Some Makers/Crafters use conductive thread for e-Textile, but by hand sewing. Today, no home sewing machine vendors recommend using conductive thread with their machines, but some of the conductive threads can be practically used for machine sewing. This article can help you finding such threads.
Note : Officially, our company (Brother Industries, LTD. ) does NOT recommend conductive thread use in our sewing machine & embroidery machine. Please use them at your own risk.
Step 2: Material of Conductive Thread
Picture of Material of Conductive Thread
There are roughly two kinds of conductive thread.
  1. Very thin metal wire
  2. Plated chemical fiber
Metal wire
Most of conductive thread available in consumer market (web shop etc.) are this kind. Many of them are stainless steel wire, some others are copper wire. Although called as thread, basic characteristic is steel wire itself. They have good conductivity, but their mechanical inflexibility makes sewing difficult.
Plated fiber
Something like silver plated on nylon fiber. These kind of thread is soft, very similar to normal sewing thread except for color. Sewability is much better than metal wire, but electrical conductivity is relatively worse.
How to distinguish
When you purchase, check the material.
  • Steel (Fe) or copper (Cu) : It may be thin metal wire.
  • Silver (Ag), nylon, polyester : It may be plated fiber.
If you already have conductive thread, contact a soldering iron on the thread. If it is plated fiber, it will easily melt.
Step 3: Basic of Thread (Thread Structure, Twist)
Picture of Basic of Thread (Thread Structure, Twist)
Sewing threads are consist of some yarns twisted together. Following twist parameters effect sewability.
Ply
Ply means number of yarns twisted together. 2 yarns twisted is called as "2 ply thread", and so on. For machine sewing, 2 ply or 3 ply threads are used in general.
Twist direction
Twist directions are identified as "Z twist" or "S twist". (see image attached) For machine sewing, Z twist is used.
Twist density
Most of machine sewing threads have 18 to 21 twist per inch.
Step 4: For Machine Sewing
First, we strongly recommend NOT to use metal wire with home sewing machine & embroidery machine.
  • It's difficult to adjust thread tension.
  • Long use of metal wire may wear and damage your sewing machine parts.
For machine sewing, you should use the plated fiber similar as usual machine sewing threads ( 2 or 3 ply, Z twist, around 20 twists per inch ). This kind of conductive thread may be used as upper thread.
Step 5: Machine Sewing Examples
Picture of Machine Sewing Examples
Attached picture shows conductive threads sewn by machine. All conductive threads are used as upper thread.
  • A : Silver plated fiber. This thread has good sewability.
  • B : Stainless wire. Very bad stitches.
  • C : Stainless wire. This thread make stuck in thread take-up, can not complete sewing.
  • D : Stainless wire. Best in stainless wire, but we can not correct thread tension (upper thread is too tight).
beaneboper (author)2017-06-16
I purchase my conductive thread from this vendor. It's my favorite conductive thread to use. It's silver lame. I
http://conductive-thread.ca/thread.html
dfab (author)beaneboper2017-06-19
Hi beaneboper,
Thank you very much for sharing the info. We will buy one & try sewing on our side!
DIY Hacks and How Tos (author)2017-05-07
I have always had the hardest time finding places that sell conductive wire. Do you have any suggestions for good places to buy it?
Thank you for your interest. We have same problem as you, buying conductive thread in US consumer market. We can buy steel wire type on popular DIY web shop (Adafruit, Sparkfun, etc.), but there may be no shop selling silver plated fiber. In case of "sewing example A" on this article, we asked thread manufacturer (Mitsufuji, Japan) to ship their product in small lot. You can contact them with this web form. https://www.mitsufuji.co.jp/en/contact/
Adafruit is where I buy mine from. They also have a bunch of sewable modules like neopixels you can use.
About This Instructable
1,050views
18favorites
License:
Bio: Brother Digital Fabrication (d-faB) provides unique project ideas and useful tips that enable all Makers and Crafters to say 'I made it !'. We are Makers ... More »
More by dfab:Bright Milky Way Quilting With LED - Arrangement of Perfboard Embroidery With Conductive Thread.ユニバーサル基板刺繍の応用 - 光るキルトライフハック - ボビンホルダーボード
Add instructable to:
