To make something useful isn't much work but you will need a few thing to make it happen.
You will need
- Some para-cord(I ended up using about 3 meters)
- Knife or Scissor (Useful for cutting, sad if you cut yourself)
- Lighter or Matches.
- Ball bearing, Steel ball or something similar(Mine was a 20mm steel ball from a hardware store)
Remove these ads by
Signing UpStep 1To get the show on the road.
Once the cord was cut, I used a lighter to melt the tips to prevent they from fraying. Once done I started with a monkey knot to enclose and hold the weight in the chain.
I am skipping a few step to avoid confusion I am ''Knot" going to show you how to make a monkey fist because you will probably end up hurting yourself. Instead I will just give you this link. http://www.animatedknots.com/monkeysfist/index.php
If you used the the link, step 19 & 20 would be replaced inserting the ball and to pull the monkey fist tight so that both end are still exposed.
works good:) knowone even tries to atack
a dorty tube sock , realy is frightful.
i need to make a stun fun type device that goes on ny backpack or elbows. many imes , when on my bike i have been attempted o be grabbed by yhe b ackpack while on he bike. They like to steal the backpack, know there is goodies in there.
like a walking /riding pinata ! urban life, luckily they have only gone after me when i was on a crest or top of hill.. On the uphill side i am dead meat
Personally, if I was in a fight and someone hit me with this, it wouldn't stop me. It'd probably just piss me off.
A key or ring (with gem) is a much better self defense weapon. A larger key can brace a fist, work as a stabbing weapon, a gem will work as a slashing weapon...etc.
A 20mm steel ball is only going to piss someone off, and probably get you hurt more.
A small keychain kubotan will do a better job. With some practice pressure points can be effective, but they also make a great fist brace.
I'd add a disclaimer saying that it shouldn't be used in self defense, or at least that you aren't liable for when a mugging becomes a severe assault because they pissed the guy off by hitting him with a little ball on some rope.
A key is pretty good by itself as a self defence weapon.
It was a weapon of fearsome proportions.
