Self-Flipping Pen Drive
13,659
141
40
Posted in TechnologyUsb
Introduction: Self-Flipping Pen Drive
About: Innovative Projects, Diy's, Life Hacks
This famous "meme" is funny cos it's true.
I am sure we all have experienced this problem.
Trying to plug In a USB cable or a pen drive
It does not fit, so you flip it around
Still does not fit, you flip it again
Now it magically fits
Yes, I know. It's not hard to memorize which way the pen drive should be plugged in. You can also see it by looking at the plug, but somehow we still manage to play the flipping game.
In this Instructable I created a self-flipping pen drive.
As long as the USB port is vertical, you pen drive will flip correctly every single time.
What will you need:
  • A pen drive, that is the same size as the USB plug
  • Nylon bearing
OD: 24mm
W: 5mm
  • Fishing sinker/weight
  • Glue
Step 1:
Find a pen drive that's the same size as the USB plug.
You can go with a bigger pen drive, but then you might need to get a bigger bearing.
Get a nylon bearing and a fishing sinker.
Step 2:
Cut/shave your sinker, so you can fit it (together with the pen drive) inside of the bearing.
Push the sinker and the flash drive inside of the bearing
Warning!
After some people suggestions, it's better to use different material weight.
Lead weight can be poisonous if you eat it or breath IN lead dust.. Even though it does not get in contact with food and we don't create any dust, it's better to use a different material weight
Step 3:
Glue it all together.
Next time you try to plug in the pen drive in the dark, hold it by the bearing.
It will flip the correct way.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    40 Comments
    I gt the feeling that this idea could be used for other stuff, but I have no idea which....
    Ha ha, this actually is useful for me lol!
    Or... you use USB type C :D
    I WONDER IF THE USB IS ON A SIDE HOW YOU CONECT IT lol
    Y SI ESTA DE LADO COMO LO CONECTAS?
    Well, it will only work with 1 side USB ports - horizontal or vertical.
    If you have made your pen drive to flip vertically, but the port is horizontal - you'll have to hold the pen drive normally - not by the bearing.
    Very cool. Thank you for the laugh and the tip.
    Cheers!
    Does not work in dark unless you're a cat :)
    *as long as the USB port is horizontal and the right way around. I actually have a computer case wherre the fron USB ports are mounted UPSIDE DOWN. grrr :/
    I agree, there is a standard, but it is ignored by a lot of devices. Very cool idea though.
    Pro tip: logo / light / slider / colour face side up. always.
    Thanks for the tip.
    colour face side up?
    Did not get that!
