3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Self Watering Garden - Using recycled water from an air conditioner
Step 3Run the tubing to the outside wall...
Once you get the pump installed you will need to run some flexible tubing from the pump to the place where you will exit the house to the garden. On the original project we just drilled a hole in the wall and put the hose through it. This worked great for the first year, but then the hose we used cracked (outside) from exposure to the UV from the sun. In this version we will connect to a brass hose connector and run outside... then connect to another hose connector. This will allow us to have flexibility and easy repair should the outside hose ever need replacement.
Be sure that the path you take from the air conditioner to the outside wall does not lay directly on any electrical boxes, lights, or run across anything that could melt it such as the flue for your heater. Likely you won't have any problems finding a good path, but I wanted to be sure the design is safely installed!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:askjerry
I like rockets, robots, and CNC.
