Step 4Moving outside...
The original design just had the hose outside, then it was updated to rigid PVC which worked but was not as easy to relocate and maneuver. The new design is very flexible and the whole unit can be moved to allow you full access to your garden if you need it for weeding and such.
We used a fitting designed to go onto a 1/4 inch ID (6mm) pipe nipple long enough to penetrate the wall and leave some threads out. We didn't want the fitting to scratch up the paint on the wall but we wanted to be able to really tighten it down to keep it secure and keep insects out.
The design was simple... add washers and tighten down the fittings to sandwich it all together into a solid attachment point for the hose.
comment
Add Comment
Add Comment
