Step 6The water bar assembly...
The bar is very easy to build, simply cut your two long peices to the proper length and glue them into the Tee connector as shown.
Glue the two end caps onto the tube and allow to dry.
Drill a series of 1/16 (1.5mm) holes evenly spaced every 2 to 3 inches (50 to 70mm) down the length of the pipe. If you use a slightly larger diameter drill, say 1/8 inch (2.5mm), then space them every 6 to 8 inches (150 to 200mm) apart.
For tomatoes I used a 6 inch (150mm) spacing... for beets and peppers I used 4 inches (100mm)... it's not that critical.
If you hang the water bar from a structure you may need to support the feed hose so it doesn't move the bar off-axis. It's good to use a level to be sure everything is watered well and evenly.
Add Comment
