loading
Step 30: Turn It On
Flick the switch to turn it on.
You should never have to water your plant again.
Now you just need to remember to refill the water reservoir.
<p>how much money is it for me to buy a self watering plant</p>
<p>how much money for i make this self watering plant</p>
<p>Could you include a schematic for the electronics layout?</p>
<p>Nice instruction. Thanks! </p><p>I used a bigger water container and also added a &quot;sensor&quot; to check when the water in the tank is empty and a little buzzer to notify me, if I need to refil :-)</p><p>Instead of the selfmade &quot;screw-moisture-sensure&quot; I used a cheap semi-professional version ...</p>
<p>hi, can u teach me how to do this? did you just follow the instruction and the coding?</p>
Can we use Arduino to program a chip so we don't have to leave Arduino in the box? Thanks
<p>wired up and everything but doesn't seem to work. Just flashes number on the serial from very high to very low rapidly. Also Relay doesn't seem to work even when i wire it up differently and force it to work, I can hear the internal switch clicking but the pump just stays on. I made sure non of my wires or solders are crossed. </p>
<p>Hello All,</p><p>Completed this project. I have a complete working project running off solar power (which is pretty awesome, just connects the usb from the Arduino to the usb port of a Goal Zero nomad 7).</p><p>My previous relay in me last comment was faulty so I got a new one. Please note that as far as I know, the above will not control the relay as it would appear. Instead of what he has above, I connected the 5v to one pin of the relay coil, and the other pin to the Arduino. I then have a wire from that 5v across the pc board and out to one of my sensors. The other sensor is hooked up totally separately from the relay with a gourd the pc board, a 10k resistor to a wire that connects to A0 (on the Arduino) and a wire to the other sensor that that junction.</p><p>hopefully this helps to those who are not having success. I am not comfortable making a circuit diagram to show what I did as I have no idea my self how to read them. I can send pics, or explain better how I did things to anyone who asks.</p>
<p>could you please can send me understanding pictures to my mail psaucedon1@gmail.com </p>
<p>Hey, would you mind sending me pictures of how you did this a.k.a. the PCP board and where the wires go to. I would really like to do this project, but the pictures and instructions aren't very well detailed. If you could email it to river@riveralexander.net that would be great. Thanks for the help!</p>
<p>thanks 4 de tip, it worked just like you said..</p>
<p>Hi! </p><p>Would you post a pic of your setup? I'm a newbie here and couldn't make it work :(</p><p>Thanks a lot!</p>
<p>not sure how to annotate pictures, the green wire from the relay goes out to any digital pin (mine goes to pin 2), the red wire on the top part of the relay goes to 5v. the red wire across is soldered to one of the sensor wires.</p><p>The black wire goes out to ground on the arduino, the 10k resistor goes over and is connected to a green wire (show) that connects to one of the analog inputs (mine goes to A0) and underneath is soldered to the other sensor wire.</p><p>The red wire on the bottom of the relay goes out to one of the parts of the pump wire as he illustrates above, the other wire goes into the single pin of the relay (which is on the ver right of the picture)</p><p>let me know if you need me to clarify anything. I know nothing about circuits or anything, just did some googling and playing around on a bread board to figure this all out.</p>
<p>I'm excited to finish this project however a little uncertain The other two red wires are soldered. I've been through the steps if you times and see where it requires is soldered to one of the sensor leads and a black 22 gauge wire is soldered to the 10 K resistor. I am completely new to these types of projects and since I am messing with electricity I want to be absolutely certain I don't mess up. I'm assuming one red wire is connected to the unused coil pin and another to the other end of the 10 K resistor where it's soldered to soldered to the relay. On an earlier step a ground was soldered to the open end of the 10k resister. </p>
<p>i can't understand how to solder the relay to the pump and how to connect all to arduino.Please help me i'm completlely a newbie with Arduino.I hope someone helps me.Thanks </p>
<p>can i get the image for the connection?</p><p>emunz07@gmail.com</p>
Hello,<br><br>I tried understanding how the the connections should be from the given description... please correct me if I've got it wrong...I am a bit confused with GND and A1 joint were we also connect the probe ...
<p>Nice solution! I'll try to make it with arduino nano and different electric pump. What about soil moisture sensor? Is this solution reliable?<br>I also find similar watering solution http://daisy.si/product/daisy-si/</p>
<p>How would you connect this to wifi and a mobile app? Is this possible?</p>
<em><strong>NOT AVAILABLE<br></strong></em><em><strong>Non-submersible electric water pump.</strong></em>
<p>is it compulsory to ad Non-submersible electric water pump to it?</p>
<p>Hi Randy, my flower has asked me to do it automatic watering, but his boss ran into a problem when trying to check the code gives error. Help my master how to fix it. When he was not at home for a long time, I have very bad without water.</p><p>That's what he can not, how to fix it)))?</p><p>Arduino: 1.6.5 (Windows 8.1), Board: &quot;Arduino Uno&quot;</p><p>The sketch name had to be modified. Sketch names can only consist</p><p>of ASCII characters and numbers (but cannot start with a number).</p><p>They should also be less than 64 characters long.</p><p>sketch_oct02b_:18: error: expected unqualified-id before numeric constant</p><p>sketch_oct02b_:25: error: expected ',' or ';' before 'void'</p><p>expected unqualified-id before numeric constant</p><p> This report would have more information with</p><p> &quot;Show verbose output during compilation&quot;</p><p> enabled in File &gt; Preferences.</p>
<p>add a ';' at the end of this line </p><p>int dryValue = 700 it should look like this </p><p>int dryValue = 700;</p>
<p>Hello sir. I downloaded the code but it gave erorr in A1;</p>
You can connect the resevator to an electric tap! Also i see no reason to use an arduino uno! Just save tons of money and space and just use an bare atmega328p
<p>Oh thats very nice dude, can u send me the pdf to my e-mail please? I wish make it for my school project it seems very awesome.</p><p>e-mail: (advocateg99@gmail.com)</p>
<p>can u plz mail me the source code? gaidar.kos@gmail.com</p>
<p>I think it is in step 19</p>
<p>that can be processed in a house right because we dont have a yard</p>
<p>someone has a video toturial?</p>
<p>these arduino codes are not working for me is there any tips so I can figure out this problem </p>
<p>I have only one question, how often do you need to change the 9V battery? My bet is that it will last around 2 days...</p>
<p>Can someone please help me with the wiring diagram between the relays, probes and the arduino. Quite confusing. Thanks in advance!</p>
<p>Hi, this is a good project. I would like to do, so I was wondering if you can share the code for the arduino? would be great if you could do it.</p><p>thanks in advance</p>
<p>The code for the arduino is given in Step 19: Program</p>
Hello River_alexander<br><br>Thanks for all! =)
<p>Would a submersible pump work as well as a non-submersible pump?</p>
Can 1 arduino control multiple pumps for independent vases?
<p>I would all so be cool if you could make it so the water in an dish at the bottom of the plant got ran though back to the water container through an tight to clean out any solid mass</p>
<p>Sure, But you may need to run them off separate power supplies. So you may need to use transistors or relays.</p>
<p>I would love one or several of theses....but the fact that I am too lazy to water my plants means that something like this is far out of my grasp....</p>
<p>Thanks for instructable Randy!</p><p>Because I had one of those moments when you get to home depot and realize that the word tubing is not descriptive enough, haha, I wanted to add that the tube size for the specific pump in this instructable is 5/16&quot; OD x 3/16&quot; ID. I couldn't find the compatible tube size needed on the pumps packaging or instructions either, but luckily you had a close up shot of the tube where I could see the size.</p>
<p>Step ten says;<br>&quot;Attach <br> an 18&quot; section of 12 AWG wire to the free pin of the 10K resistor. <br>Solder a 6&quot; section of black 22 AWG wire to this joint.</p><p>Attach an 18&quot; section of 12 AWG wire to an unused part of the PCB. Solder a 6&quot; section of red 22 AWG wire to this joint.&quot;<br><br>However, the pictures show two additional wires coming off the PCB. You can see them again in images from steps 12,13, 15, and 22. Step 23 talks about where the OTHER end of those wire go (connecting to the Arduino), but I am wondering where they connect exactly on the PCB. I seem to be missing the step where it mention when and where those wires are connected.</p>
<p>Did you ever figure out what wires went where? I would really like to do this project, but I can't get it to work.</p>
<p>sorry could you send me the schematic and program details as well thank you very much it would come in handy </p>
<p>hi, could you send me info as I want to do this as my final project. christianjay95@hotmail.com</p>
<p>hi sir, thank you for the info. can you send me on my email the full information and the program because the above info is quiet complex for me. I want to propose this to my professor for our thesis project. This is my email arjie.carolino@yahoo.com</p><p>Thank you sir..</p>
<p>I can use a air pump instead?</p>
<p>can i use bigger water pump</p>
About This Instructable
409,782views
967favorites
License:
Bio: My name is Randy and I founded the Instructables Design Studio. I'm also the author of the books 'Simple Bots,' and '62 Projects to ... More »
More by randofo:Spooky Whispering Prank Custom Print Kimono Mad Scientist Extension Cord
Add instructable to:
