Step 13: Time to plant!
Your table is finished! Get out there and plant some vegetables!!
**Please note I will be updating this instructable as the season continues with the progress of my self-watering veggie table. Check back here for the updates!
You can also see my full garden here.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
Cheers again.
In a much more tropical area such as you describe Tushar, I could see the advantage to having maybe 2 overflow pipes per container. Just remember that you need a straw to connect to the water reservoir inside.
Please see steps 11 and 12 in this instructable to see more detail to what I am talking about. Good luck! I look forward to hearing how your project goes!
cheers.
These containers have been in my fence for about 12 years now. Each spring I add some more soil to the top to replace what soil decomposed.
I have grown everything from tomatoes and squash to flowers in these containers.
I watter with a tube setup connected to a faucet. I water about every 3 days in mid-hot time.
It is official zone 8b here in the Portland, Oregon area, but effectively it is zone 9a most years. The old saying in Oregon is, " What did you do last summer?"
"I missed it, I went to the beach." We do get a lot of cloudy weather.
I'd also cover the white basket with window screen or a rot proof fabric, to keep your soil mix from getting into the reservoir area and displacing water.
We are far enough north to make it not possible to grow a lot of plants because of the extreme low temps we get here. But hot enough to make it miserable.
From my experience, I drained my water barrels but not my self-watering planters. In the D.C. area, we routinely get below 20 degrees F, which is below freezing, but not sub zero temps. Last winter my tubs did not crack and I am not sure why, but I was glad.
I've got a potting bench that uses the same style of tub under a slatted top, and I don't give it a second thought when winter rolls around -- it's held up fine for the last 3 midwest winters.
You have had a lot better luck than I have, on the freezing and breaking issue.
But I will agree the tubs should be protected from the sun.
Gordy in MN
