Make your own Self Watering Window Boxes.
Here's how...
Remove these ads by
Signing UpStep 1: Step: Gather your Supplies
-A 24" plastic Window Box Liner
(available at Lowe's in the Gardening Section)
-24" Galvanized Cage Wire
-A small submersible water pump
(available at Harbor Freight Tools for under $10)
-4' of vinyl hose sized to match the diameter of your water pump nossel
(available at Lowe's in the Plumbing Section)
-Potting Soil
-Plants
-Plumbers Putty
-Two pieces of felt
-A Dremel with your smallest drill bit
-Scissors
-Wire Cutters
-Automatic Timer
A note about the water pump... Water pumps are rated based on how high they can lift the water and how many gallons per hour they can pump. This water pump will only need to lift the water a few inches, and will won't be required to cycle lots of gallons of water. The tiniest water pump you can find will probably suffice.
Visit Our Store »
Go Pro Today »
http://drdunc1000autogardens.blogspot.com/
I just wrote an instructable about self-watering indoor plants: really self-regulating, and no powering needs.
It is here: http://www.instructables.com/id/Self-regulating-watering-system
Hope someone find it useful.
Best wishes,
Gustavo.
This is interesting - I've been trying to figure out how to make windowboxes self-watering, for shallow things like lettuce. I grow tomatoes in a couple Earthboxes, and have been working on DIY variants for other things, but the lettuce does poorly in the Earthboxes because it's so far from the reservoir to their roots (I think - they wilt and die, even with a full reservoir). This would solve that nicely.
http://www.insideurbangreen.org/diy-sub-irrigation/
It'd probably be pretty easy to modify these instructions to build the capillary action version. Just replace the pump + tube with something that will wick up water. A short piece of rope could work, or you could even just wrap the entire reservoir in additional felt. You just want to make sure that whatever you use will wick up water well, that it reaches the bottom of the reservoir, and also makes good contact with the felt in the bottom of the soil compartment.
check out 'water detector' or 'leak detector' kits and you'll see what I mean.
For people using this outside it will be necessary to drill a overflow hole in the side of the container below the level of the wire. Otherwise rain could over fill the container and drowned your plants. Or you could drill a hole near the bottom of the container and mount a elbow with some clear plastic tubing standing straight up to act as a site glass. Cut the tubing to the proper length and it will act as an over flow.
Great idea
