Self-Watering with Yarn by moxiepurple
Featured
A friend told my Mom how to do this, she has been using this method for several years.
You will need:
Yarn (I am using cheap acrylic Red Heart brand)
Scissors
Flower Pots
A drip try for flower pots
Plants
Dirt
Step 1: Braid Yarn & Insert into Pot
Cut six strands of yarn about one foot long (you want it to reach from the dirt line to about 3-5 inches hanging out of the pot, depending on the size of the pot), tie a knot on one end, braid, and tie off the other end. Poke one end through the hole in the pot, and pull out a few inches.
There's no measurements here, since you can do this for any size/height pot you would like.
iminthebathroom says: May 10, 2011. 12:00 PM
uh oh, crafty pot heads will be scoring this on 5 stars! kidding, neat idea!
Mouserz says: Jul 23, 2012. 11:37 AM
you bet!
dana-dxb says: May 24, 2011. 4:47 AM
this is shorly a good idea
Darth_Reese says: May 19, 2011. 5:36 PM
Smart having the yarn act as a wick. I'm going to try this.
q3qyuu says: May 11, 2011. 7:51 AM
this is awesome!
ChrysN says: May 10, 2011. 3:56 PM
Clever idea!
bruc33ef says: May 10, 2011. 7:14 AM
This is a great sub-irrigated planter (SIP) variant. The thing I really like about it is that you can use readily available materials like standard flower pots without having to cut them up and drill holes. In fact, it probably doesn't even need an overflow hole in the side as do most SIPs.
About the only way I can see to improve on it would be to cover the water tray to reduce evaporation. But that would be very easy.
Very well done!
moxiepurple (author) says: May 10, 2011. 7:46 AM
I didn't know what it was called, but we did something like that last year with big plastic tubs and pvc pipes so we could have a garden and not spend a ton of money the first year.
You are right, there is no over flow in the side, I did not have to do anything different from a normal planting other than braid some yarn and add it to the pot. I think I will cover my water trays with dairy container lids. Thank you for the suggestion.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
