3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Self watering recycled plant pot for growing herbs and flowers
Inspired by bbullet's Self-watering recycled vase instructable, this is the method that I have been using to make dozens of self-watering recycled planters. Thanks, bbullet!
The way that I am making these uses 2 or 3 liter soda bottles and it supplies the soil with just the right amount of moisture for the plants to grow. It's a little different than bbullet's way, but it's still made with recycled bottles and produces fantastic results all for the cost of a pinch of seeds!
Step 1Materials
Materials
You will need to gather these materials:
  • One 2 or 3 liter soda bottle with the cap
  • A piece of newspaper, a piece of plastic from a bag or a piece of aluminum foil
  • Cotton string
  • scissors or knife to cut the bottle
  • a drill (or something similar) for making holes in the cap
  • tape (optional)
*paper or some other decorative cover to keep the light out
96 comments
1-40 of 96next »
Jun 7, 2008. 4:44 PMTidnull says:
I don't the print would be a problem but the newspaper seems like it would work like a peat pot. Water a peat pot and within 24 hours the pot itself has soaked up all of the moisture, leaving the roots to dry out. To me, the black trash bag would be the best choice, as it does not soak up moisture and does not run the risk of letting light in.
Apr 4, 2011. 10:38 AMKittyF says:
the trouble with a black trash bag is if the sun comes in the window it can overheat the soil and the plant roots. it's possible it could kill the roots, and the heated soil might dry out sooner as well.
FWIW
May 1, 2010. 10:35 PMtvandang says:
perhaps i did not read this article clearly but do we put water in the soil or in the reservoir so that the the soil will suck up the the water from the reservoir via the strings?  i am not so clear about this.  so when we plant the herbs do we fill the reservoir or water the soil?  sorry if the questions are idiotic.  thanks!
May 5, 2010. 4:38 PMLittleWolf says:
Great instructable! I really like recycling, but only as long as they serve a purpose. Would it affect it on any way if the whole container was permanently decorated?
Oct 15, 2010. 3:27 AMpravs2k says:
I first tried out with pebbles at the bottom.then graduated to two piece ones.Now I make two piece ones but with decoupage covering the whole bottle Cant pull out the top part to see how much water there is left. to overcome this problem I have left the flat part of the bottle clear and drilled a hole about two inches from the bottom for the excess water to flow out . The bottles are all placed in a basin of water for a while and once they are full ,they are taken out and left out for the excess water to drain out. I used fabric and jute and also paper napkins to decoupage the bottles. Also mat and bamboo screens.Plan to grow lettuce and herbs, but at the moment I have all sorts of plants.Just one had a problem- the roots found their way into the reservoir because I had drilled an extra hole in the lid for water to drain into the the bottom part .Couple of plants wilted a bit -the soil was dry.Dont know what happened.
May 20, 2010. 11:27 AMgeekcore says:
Recycling, yay!
 I just made four of these today after having some trouble with my oregano and thyme washing away when I try to water from the top and not staying moist enough in general.
I left the newspaper out, though.
Jul 16, 2010. 10:30 AMGoodhart says:
This would be great for seeds like coriander, too.
Jun 1, 2010. 9:10 PMsail4free says:
You can view my sub-irrigated instructable here:
http://www.instructables.com/id/How-to-Build-Your-Own-Growing-Containers/
Using the Google search feature with "sub-irrigated", my instructable was #3 . . . I think yours was #1! My thinking has evolved towards using a five gallon bucket for larger plants, but you could do the same thing on your smaller scale by removing the tapered neck of the clear bottle. Drill a small overflow hole at the desired maximum water height and fill with pea gravel to 1/2" above the overflow hole. This guarantees a crucial air gap between the potting mix and the water reservoir, so over-watering is impossible. Then a piece of Dupont's 15-year landscape fabric is used to keep roots from drowning in the reservoir. Then the bottle is filled with planting mix and is ready to plant. It's important to fully saturate the mix as you go -- any excess drains out the overflow. The bottle should be painted or shaded with a decorative cyclinder. I have ideas for auto-watering too so the water level remains constant. I hope to detail all this in my 2nd Instructable SOON but haven't put it together yet.
May 22, 2010. 5:53 AMKhiemTran says:
Genius!
May 16, 2010. 5:57 PMjunkk29 says:
 Thank you so much for posting this instructable, now I have a new home for my Oregano and Rosemary plants :)
May 2, 2010. 11:35 PMtimbit1985 says:
Contrary to popular belief, plant roots do just fine in sunlight :) The reason that 99% of pots are opaque is because it helps nurseries control algal growth in their soil. I have over 20 plants in transparent pots, with various exposures to sunlight. All of them are thriving.
Cheers,
Tim
May 2, 2010. 4:34 PMtreehuggingwolf says:
This is really cool! It addresses the problem that recycling plastic isn't very profitable. This way your local recycling center doesn't loose money sorting it, and it still stays out the landfills. Bravo, sir! You've also solved a problem for me. I've been using the bottom parts to catch excess water but a plastic cup for the pot. This way one bottle will make a complete pot.
May 2, 2010. 10:28 AMChewie42 says:
Did you try a coffee filter?
May 1, 2010. 6:52 PMarcherj says:
This is a good idea, well thought out and presented--also some good suggestion and comments from others. Good luck with your big project!
There are some serious environmental questions about the use of peat moss: look at the whole picture on Wikipedia. It's a question of choice, but you it's always a good idea to look at both sides of the picture.
Personally, if there's a rational argument regarding environmental issues, I try to find an alternative. Maybe a compost bin and making your own homemade "peat."
Mar 20, 2008. 5:32 PMdwream says:
Very clever. Thanks. A suggestion: because algae can be a problem in the reservoir, it is helpful to wrap the entire container in newspaper or foil to exclude light. It also reduces light, and improves appearance, if you can fit the planter into a tall porcelain vase.
Mar 21, 2008. 8:33 AMbqbowden says:
(removed by author or community request)
Jun 30, 2008. 2:32 AMdungeon001 says:
New to gardening and don't know much about growing anything so maybe this has some problems I don't see. But in areas prone to moss/algae growth on roof tops copper and/or zinc bars are effectively used to kill it. They attach near the peak of the roof and when rain washes over them it carries enough with it to kill the algae. If the hydro/aqua system were to circulate through copper pipes (perhaps via an aquarium pump) that might be adequate to stop or slow down algae growth. Or perhaps it could be circulated over a small piece of one of these bars. Don't know how well or if it will work at all. Just an idea I had while reading the comments here.
Apr 30, 2010. 9:33 PMMr. E Meat says:
I'm not sure of the toxicity of copper on the plants(or the levels that might leach off of the pipes) but I know that increased copper levels will harm invertebrates (like shrimp)... Also, I think you want to avoid mixing metal types in plumbing ot avoid excessive corrosion.
Apr 8, 2010. 3:05 PMrobinmaille says:
 Excellent.  Clear, concise, complete.  Ideal instruction on the how and why.  There are some young children I will introduce to in-home planting with this idea.  Thank you.   Can you add water to the reservoir via that air hole you make if your watering 'can' had a fine enough nozzle?  Say, water pistol size?
Apr 2, 2010. 3:41 PMtimbit1985 says:
Hey,
Did you know that it is actually a common misconception regarding roots and darkness? The reason 99% of plant pots are opaque is due to commercial growers preferences. Plant pots are opaque to limit the amount of algal growth that is possible. In a home environment, algae is not likely to bloom in your soil. I have over 20 super healthy plants, all of which are planted in transparent pots. Having a transparent Sub Irrigated Pot is actually very handy, as you can see where the water level is, which allows you to KNOW when to rewater, as opposed to simply guessing.
Great instructable!
Tim
Mar 25, 2010. 8:07 PMgizmogrl says:
All I have to say is I am stoked to to try this.  Imagine all the applications: genius!
Mar 1, 2010. 2:38 AMmicorneus says:
Great post, but may I suggest:
1. Use 2 ply acrylic yarn for the wick, it wont break down as fast as natural fibers. Cost - $2-3 for about 40-50 yards.
2. Place a copper penny in the reservoir to deter algae growth.
Aug 22, 2009. 12:54 PMstormys says:
What kind of soil do you use for plant your Venus Fly Trap?
Sep 3, 2009. 3:40 PMstormys says:
Thanks for the tip, your Fly trap looks healthy. :D
Oct 11, 2008. 5:24 PMaleeoop says:
Does anyone know if BPA can leech into soil and then plants from plastic containers? I know this sounds paranoid, but it worries me sometimes.
Jun 20, 2009. 9:29 AMKira53 says:
This is a fantastic instructable. It was very clear. I made a different type of self watering planter with plastic milk cartons and I think this will work better. I especially like the idea of the newspaper "cup". That will make transplanting less traumatic for the plant. Thanks.
May 14, 2009. 3:22 PMtphilp74 says:
OMG!!! I'm so doing this tonight. I have some mesclun, cilantro and other herbs I was about to start in Jiffy pots, but hell... this is way awesome.
Mar 14, 2009. 8:49 AMgreenpeace says:
Great****This saves time and gas. I will keep my recycled bin at home and make my own treasures. Thanks. This made my day +++++++
Feb 8, 2009. 8:12 PMTidnull says:
i have been using this model since august for marshmallow, spearmint, and chamomile and i just transplanted them outside. the plants all grew in a window to a few inches and they are doing fine in the garden now.
Jan 1, 2009. 9:06 AMRunningSneaks says:
Whoa! This is awesome! Really, what a great thing for someone like me who forgets to water plants but loves to cook with fresh herbs! It would make a great gift too! Or a project for a workshop!
Dec 14, 2008. 11:56 PMassimalmaiha says:
thank for every body
1-40 of 96next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:iPodGuy
Just your average handyman.
