Step 3Fill Tube
To do this, I simply drilled a bunch of holes through the tube and crimped the end. Drill enough holes to eliminate pressure build up and to cover the desired area inside the bottle.
To crimp the end, simply heat the end 1/2 inch or so, without burning it, and pinch shut with a pair of pliers and hold. If it doesn't seal shut, heat it a little more and try again. Heat slowly to prevent discoloration, but enough to liquify the vinyl. If you use another material, terminate accordingly.
Add Comment
