Semi-Automatic Nerf Nitron Mod
 by BrittLiv
Contest WinnerFeatured
In this Instructable I'm going to show you how to mod a Nerf Nitron into a semi-automatic gun. You might ask yourself, who in their right mind would turn a fully automatic gun into a half automatic one? The answer is simple, it gives you better control, is lighter and who has ever fired a Nerf Nitron knows how ridiculously slow it normally is. This combined with a voltage mod makes this gun simply amazing (now it takes about 5 seconds to fire 20 shots).
This mod is not for beginners, don't proceed unless you are certain, that you are able to do it.
  before (9V)      after the mod (14.8V)
Weight [g] 1577 789
Length [cm] 65.5 41.5
Time to empty 20 shot magazine [s]      12 5-6
It also shoots a lot further, but I don't have the possibility to compare them at the moment.
Step 1:
What you need:
•  Nerf Nitron
•  Modeling clay (e.g. Apoxie Sculpt or Milliput)
•  Body filler (optional, e.g. Bondo)
•  Tension spring
•  M3 screw 20 mm long
•  sanding paper
•  Strong, two component glue
•  4 X AAA battery holder case (3 x 3.7V batteries and one 1.5V)
•  Primer, paint, clear coat
•  Silicone Spray Lubricant
Tools:
•  Hot glue gun
•  Strong two component glue
•  Soldering iron, solder
•  Phillips screwdriver
•  Pliers
•  Fretsaw or scroll saw
•  Drill (3 mm drill bit)
•  Diamond file
beastlyawesome says: Jan 14, 2013. 6:11 PM
http://www.youtube.com/watch?v=I9wSw06pF40&playnext=1&list=PLB7664E332EC893B6&feature=results_main
ray74 says: Nov 30, 2012. 8:12 PM
Sweet :)
poofrabbit says: Nov 27, 2012. 8:47 PM
Hey congratulations on being a finalist in the hack it contest! Good luck to you!
taowyman says: Oct 26, 2012. 5:26 PM
the foamy lookin thing thats for the gray thing to slide on right? the thing superglued to the orange thing u added from the blaster
bob-obob says: Sep 24, 2012. 12:29 PM
this would be SO MUCH better if there was even just ONE "before" picture of what the entire blaster looked like
BrittLiv (author) in reply to bob-obobSep 26, 2012. 1:55 AM
I've uploaded a comparison picture, I hope you like it.
jongscx says: Sep 23, 2012. 10:06 AM
ANGEL BREECH!!! kidding...
You could've also put an interrupter circuit on the motor and made a switch-mode blaster.
Edgar says: Sep 23, 2012. 8:58 AM
All right!
Do use the Bright-color attachments whenever you go out, your idea is just as neat that way.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
