Introduction: Semi-Bivy: Keep Your Sleeping Bag Dry and Warmer
Picture of Semi-Bivy: Keep Your Sleeping Bag Dry and Warmer
If you have an tent that has lost or never had sufficient waterproofing on the bottom, then you probably know how unpleasant it is to wake up in the middle of the night and discover that you are sleeping in a puddle. The Semi-Bivy provides an completely waterproof layer that also provides insulation from the ground, keeping you warm and dry.
For the backpacker who wants to shed weight the Semi-Bivy would keep the bottom of your sleeping bag dry when sleeping directly on the ground, even when it's moist. With a tarp to keep the rain off and maybe a bug net you could be conferrable in most conditions (with the right sleeping bag of course) without being trapped in a normal tiny bivy sack.
It could also be added to a hammock setup to keep the wind from blowing all of your warmth away, allowing camping season to extend later in to the colder seasons for less then $15.
Step 1: Materials and Tools
Picture of Materials and Tools
Materials
  • Emergency Blanket (The SOL brand is best for this project because it is durable and made to be reused unlike most Space Blankets)
  • About 10 ft of paracord
  • Stretch Cord (Optional, can be used in place of paracord on the last step)(Thanks to mike.southey.94 for the idea to add this.)
  • Electrical Tape
  • Strong Thread
Tools
  • Marker (Sharpe works well)
  • Tape Measure or Ruler (optional)
  • Scissors
  • Sewing Machine
  • Lighter or Candle
Step 2: Cutting the Emergency Blanket
Picture of Cutting the Emergency Blanket
The blanket needs to get cut down to fit around your sleeping bag better.
  1. Lay out the blanket inner side up (for the SOL this is the silver side)
  2. Lay out your sleeping bag centered on the blanket. If you plan to have your sleeping pad inside the Semi-Bivy then also lay it down. (If you put the sleeping pad in the Semi-Bivy it would be harder to roll off of it during the night.)
  3. Trace the outline of your sleeping bag.
  4. Add some extra space to the outside, the more space the higher the walls of the Semi-Bivy will be, therefor the deeper the puddle you can sleep in while staying dry. My sleeping bag is 16" shorter then the blanket, so I added 8" extra on all sides.
  5. Cut along the outer line.
Step 3: Making the Channel for the Paracord
Picture of Making the Channel for the Paracord
For the blanket to form a bowl around your sleeping bag we will use paracord to gather the edges, to do this there needs to a channel the runs around the edge of the blanket.
  1. Cut several sections of electrical tape, about 4-6" long.
  2. Fold over a section of the edge the of the blanket about 1/4''.
  3. Put the parcord next to this fold so that it will be inside of the next fold.
  4. Fold it again, this time for about 1 1/2", to create part of the channel.
  5. Stick it in place with one of the pieces of electrical tape. (near the head and foot there is a bit of a curve, don't be afraid to bunch up the fabric a little)
  6. Repeat until you have gone all the way around, leaving a small opening for the two ends of the paracord to stick out (I put mine near where my head would be but the placement of this is flexible).
Step 4: Reinforcing the Channel
Picture of Reinforcing the Channel
Although the electrical tape holds pretty well, reinforcing it by running it through your sewing machine will help it stand up to the stresses of multiple trips.
  1. Set up your sewing machine.
  2. Start sewing one end of the opening for the paracord. Sew back and forth a few times to prevent unraveling. I used a zigzag stitch on the biggest setting to keep the holes far a part to prevent taring.
  3. Make sure to keep the foot of the sewing machine on the electrical tape to prevent the teeth underneath from taring the blanket.
  4. Sew all the way around until you reach the other side of the opening. Finish off with sewing back and forth again.
Step 5: Tightening the Paracord
Picture of Tightening the Paracord
Now that we have the channel we can tighten the paracord to give the Semi-Bivy it's shape.
  1. Lay out the Semi-Bivy and put your sleeping bag in the center.
  2. Start pulling the paracord until it is tight enough that the head and foot don' t slip off too easily, but loose enough so that you can easily get in and out and so that it will not constrict your movement.
  3. Cut the parracord.
  4. Either tie a knot and melt it a little with a lighter or candle, or simply melt the ends together. Make sure that you pull the ends of the parracord away from the blanket so it doesn't catch fire!
Step 6: Keeping the Sides Up
Picture of Keeping the Sides Up
Because the sides tend to fall down, letting water in and heat out, we will add some paracord across the top of the sleeping bag.
  1. Get in to your sleeping bag and decide and mark where you would like the strings to be. (I put mine right around where my knees would be and a few inches below my hips so that I could sit up if i needed to).
  2. Cut a small opening into the channel where the string is at each of the marks. (Careful not to cut the paracord)
  3. Add a piece of electric tape to edges to prevent ripping.
  4. Take a piece of paracord or stretch cord and tie it to the paracord that is in the channel.
  5. While in your sleeping bag tie the other end of the piece of paracord to the paracord at the other side, making sure that it is tight enough to keep the sides up but loose enough to allow movement.
Congratulations! Your done! Now it's time to go camping!
turkey70 (author)2015-11-04
Nylon foil hose
sidmarx (author)2015-09-13
Or how about just tying a rectangle of silnylon together at the head and foot of the sl. bag, creating a boat shape to enclose the sl. bag?
Heeboore (author)sidmarx2015-09-28
You could replace the emergency blanket with the silnylon if you wanted, but it would be a little more expensive and wouldn't reflect your heat back like the emergency blanket does.
mike.southey.94 (author)2015-09-27
May I suggest stretch cord instead of paracord across the top to reduce the risk of tearing with excessive movement? Great Instructable, clear and simple!
Heeboore (author)mike.southey.942015-09-28
I think that would work really well! Thanks for the idea!
YaënD (author)2015-09-11
seems to be very interesting for me often sleeping in my van when working away. good to keep me hot. thanks
MattDoesThat (author)2015-09-11
I love this. I've woken up in a puddle a time or two myself, and I'd just as soon not repeat the experience.
I have one suggestion, which is to use gromets for your top crossing cords. That might help prevent tearing over a longer term. You could also use tarp clips which would allow you to move them to different places, but that would be a bit more to carry.
FlorinJ (author)2015-09-10
Or just slip your sleeping bag into a wide nylon foil hose. Have slept in the rain with such a setup. Laid it so that my head was near the trunk of a fir tree (that spot always stays dry, no matter how strong the rain), feet outwards, and haven't had a problem with wetness or cold.
dragonlily (author)FlorinJ2015-09-11
where might one get something like this?
IADORAK (author)2015-09-10
This looks like a lovely creation!! I got a little confused at the creation of the first channel for the paracord. But the end product looks FANTASTIC! Thank U for sharing Ur creativity!
thepantheonzaibatsu (author)2015-09-09
This is a great idea!!! We'll done!
KristinM5 (author)2015-09-08
Love the idea. Already have the sol escape bivvy, now I just need a sleeping bag. Would you recommend a mummy type or would this work with a square style bag as well?
Heeboore (author)KristinM52015-09-09
I think a mummy bag would work best, but it would most likely be possible with a square bag if you added extra room for the corners and rounded the edge of the blanket when you cut it.
KristinM5 (author)Heeboore2015-09-09
Ok thanks. I have a toddler and I am thinking if she had to sleep with me, a square bag may be a bit better fit for 1.5 people than a mummy. Although she has her own "Olaf" sleeping bag now, (child size) so I may just get another bivvy for her bag and a mummy bag for me
ashleyjlong (author)2015-09-08
Great idea! Practical to assemble and practical to use.
thijsv (author)2015-09-07
Nice hack that also looks good. How many trips did the emergency blanket hold? Maybe you can also reinforce it at the bottom?
Heeboore (author)thijsv2015-09-08
I haven't had time to test it more then once yet, but the SOL emergency blanket is very durable for its weight. If you want something a little stronger SOL also makes a heavy duty emergency blanket, witch is designed to be used as a ground cloth.
bravoechonovember1 (author)2015-09-08
awesome first instructable!
welcome to the community!
bwh13 (author)2015-09-08
Nice one!
kylegilbert (author)2015-09-08
Wish I had used this setup on some of my camping trips in the past.
Nice ible, and great first post! Keep them coming!
Voted for you in the contests.
About This Instructable
37,751views
495favorites
License:
More by Heeboore:Impossi-bolt Brain Scramble (Cake Scramble)Semi-Bivy: Keep your sleeping bag dry and warmer
Add instructable to:
