SemiAutonomous Submersible Robot for Underwater Research
28,794
100
32
Posted
Introduction: SemiAutonomous Submersible Robot for Underwater Research
this is a submersible robot (a little submarine) that can be operated in manual or semi-autonomous mode.
FOR DESCRIPTION OF WHAT ALL THE FILES ARE, GO TO THE LAST STEP
Step 1: Circuit Diagram
TO BE ABLE TO READ THE DIAGRAM, CLICK HERE:
https://static2.instructables.com/ID/F7S/YPXY/Q6SEP27UXHB/4AA2923407121029853F001143E7E506.gif
the rest of the pictures show the construction of the sub. It was made out of two C channels connected by an aluminum sheet. A skid was added to the bottom to allow the sub to skate over the bottom to gather quantitative video samples of the ecology. The skid and two C channels (necessary to hold the large # of sensors desired) was a little heavy so the sub had trouble moving up and down using it's one vertical motor (although there is a fourth small motor in the diagram, we never added that). You should definately be able to make the body a lot lighter so that a single vertical trolling motor will be fine.
Step 2: Code and Documentation, Etc.
--SmartConsole.bas is a QBasic program that runs in DOS or win3.1 It's an interface that takes data from the subs sensors and displays them graphically on the screen (tilt, yaw, etc)
--SmartSea.bsx is a basic program that runs on the BSX basic stamp (while building the thing I used a BSX, I put another basic stamp in the diagram because the bsx had one too few pin for sensor interfaces)
--BS1_BOBIII is code interfacing the BS1 with the bobIII video overlay chip
--Purchase lists show everything you need to make this.
--The tutorial talks about how to use everything if you somehow make the exact same thing as I do.
--The final paper talks about why I picked certain parts, overview, etc.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
  • Sew Warm Contest 2018
32 Comments
This might be of interest to you, but deadline is this Friday!
There are better ROVs out there than this one but thanks for the heads up :)
simply incredible!! nice job!! congratulations!!
a question, where did you find the motors??
The link for schematic doesn't work.
what is the estimated total weight of your submersible robot? :).... by the way, good work :)
hm, I don't know, was a while ago. maybe 60 or 70lbs? that's just ballpark. that's why we had to add the styrofoam. we should have built it with pvc tubing like everyone else, but we used to heavy duty plastic for the body that was not necessary.
My brain just died.. I'll be coming back when I understand what this is
impressive!
very nice submarine,
would you consider submitting it to the new ROV group ?
