3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Send Music over a Laser Beam
WARNING: this project involves the use and modification of laser devices. While the lasers I suggest using (store-bought red pointers) are relatively safe to handle, NEVER LOOK DIRECTLY INTO A LASER BEAM, BEWARE OF REFLECTIONS, and be EXTREMELY CAREFUL when MODIFYING a laser product. Also, I am not liable for anything stupid you do.
Here is yet another thing to do with those promotional laser pointers: send music (or data) from point A to point B over the laser beam using amplitude modulation. All it takes is pointing the moded laser at a detector, and music can be heard from an attached amplifier. The range and quality (or data speed) can vary, but I have gotten a HALF MILE of range with excellent audio quality and around 300bps of throughput.
The image shown here is the transmitter and receiver working across my desk during a test.
TO SEE HOW TO USE TWO LASERS TO TRANSMIT TWO MUSIC CHANNELS AND MIX THEM WITH A PAIR OF SUNGLASSES, check out the blog post here.
A video of the system working can be found here: http://video.google.com/videoplay?docid=6895048767032879458&hl=en
Much inspiration for this project came from http://sci-toys.com/scitoys/scitoys/light/light.html#laser_communicator
Step 1Gather Materials
Gather Materials
To send music over a laser beam you will need the following parts, most of which can be gotten for less than 5 dollars at radioshack total (besides the pointer, which probably costs $15). If you are on a tight budget, try replacing the laser with a red LED and a 100ohm resistor attached in series.
for the transmitter:
a laser pointer
batteries (D-cell work best)
potentiometer (variable resistor) 50k ohm or less
audio source (iPod, cd player, mic preamp, PC line-out, etc.)
some wire (cat5 aka ethernet cabling works best)
toggle switch (a turbo switch from an old PC works well)
audio transformer (can be pulled from audio equipment)
1/8" audio jack (can be gotten from the end of a headphones cable)
for the reciever:
phototransitor (photodiodes or IR detectors also work)
1/8" audio jack
some more wire
high-gain amplifier (laptop with mic input, or mic preamp plus amplifier)
magnifying glass (helps at great distances)
tools:
wire cutter/stripper
soldering iron and electronics solder
tape (clear and/or electrical)
digital multimeter (can be useful... not realy required)
tripod (helps for aiming laser at a distance)
empty pizza boxes with white backs (for finding beam and for adjustments)
some assistants
145 comments
1-40 of 145next »
Dec 4, 2011. 5:36 PMNGinuity says:
I assume you're using the transformer in that manner to "step down" the level of the input signal as well as modulate the DC going to the diode. Is that correct?
Aug 17, 2011. 4:39 PMALogan97 says:
Is the audio transformer necessary? I forgot to buy one and don't want to go back out to radioshack to get one.
Mar 21, 2011. 7:32 PMZack1296 says:
YA CAKE! btw the project is awesome
Apr 11, 2009. 4:45 PMchubyatyahoo says:
can you replace the laser with an led
Feb 6, 2011. 9:56 AMSwishercutter says:
That would be an Optoisolator...at least by the time you actually got the led close enough to eliminate noise and get an effective signal...but basically an optoisolator uses an LED coupled with a phototransisitor in order to electrically isolate the control circuit from the circuit being controlled.
May 22, 2009. 6:44 PMraykholo says:
i would seriously not recommend doing that will it work? yes is it effective? absolutely not an led is not a focused beam, cannot be used over long distances like a laser can, and it is more prone towards the distortion as the light is more spread out. The laser points light precisely at the photo diode, so that is the light which is converted to audio. Theoretically, using an led would require total darkness so as to eliminate that interference. Give it a shot and tell how it went!
Jan 28, 2011. 5:08 AMXOIIO says:
Could you just hook a laser diode to the audio output and a reciever to a microphone input? IT seems like it would make sense.
Jul 19, 2009. 1:39 AMWarlrosity says:
what is a duh? is it an iPod knockoff?
Jan 13, 2011. 2:02 PMGameNox says:
No. It is an IPod. It means that you need music. Your'e a duh! =P
Jun 14, 2010. 9:02 AMjelte1234 says:
actually: would ripping apart a wireless cheapy headphone not also work, and then replacing the leds with a laser? or is this a bad idea?
Dec 13, 2010. 2:07 PMinquist says:
No the LEDs are in the transmitter, and they have a wide angle so your headset can receive from anywhere in the room. A laser transmitter has to point straight toward its receiver, in this case William Tell style
Oct 1, 2010. 3:17 PMep0317 says:
Could you please specify the type of audio transformer that you used? thanks..
Mar 7, 2010. 5:52 AMcaseyC088 says:
would it be possible to make a two way radio sort of thing if you made two of these??
Nov 8, 2009. 12:20 PMlazer155 says:
 Is the potentiometer absolutely necessary?  I dont have one on hand so I want to know if I can use just a resistor.  Can I use one of those photocells instead of the phototransistor?
Nov 11, 2009. 4:31 PMlazer155 says:
 What is the potentiometer for?  I got it working without a pot or a resistor.  Does the pot filter out static and background noise?
Nov 8, 2009. 12:55 PMlazer155 says:
 Also how would I hook this up directly to a speaker instead of having to put it in a mic port?
Nov 3, 2009. 3:39 PMayman deabes says:
nice project
Sep 9, 2009. 9:50 AMadhwaith says:
hey... i don't seem to be able to get any music across... is there any way of testing if the transmitter works???? and i'm using a 10k ohm potentiometer, could that be a reason???
Aug 18, 2009. 1:15 PMFirecrow says:
when i point my laser beam at the reciever i get no sound.. Does this mean that my laser beam is not good enough? and if so could i just connect it to a infrared led?
Jun 23, 2009. 5:54 PMGamernotnerd says:
Can you post some pics of the sensor lab?
Jun 17, 2009. 2:29 PMUbuntuNinja says:
My laser uses 3 button cell batteries (4.5 volts) so can i replace the 3 volts in the diagram with 4.5 volts to give the laser a reasonable brightness?
Jun 18, 2009. 12:56 PMUbuntuNinja says:
Can you help me to understand how i should wire up my LM386 amplifier IC? Here is the schematic of the IC:
Jun 18, 2009. 12:18 PMUbuntuNinja says:
Yeah i think it is actually better to use less voltage than the laser takes for normal operation (not in audio circuit) because it will be receiving extra voltage from the ipod which which would create a voltage greater than what the laser is build for. Since we are talking about lasers, overvoltage could damage the laser.
Dec 19, 2007. 2:57 PMashes63 says:
hope this one works!!
Jun 17, 2009. 1:54 PMUbuntuNinja says:
That schematic is very helpful. I like how you correctly represented the different ways to wire the transformer. I was actually having difficulty figuring out which side of the transformer was supposed to be wired to what looking at the authors diagram.
Jun 15, 2009. 4:09 PMUbuntuNinja says:
Here is the schematic for the circuit without the black background, for easy and efficient printing: http://www.instructables.com/file/FYUF1DKFVW22CNV/
Here is that same file in Inkscape SVG (scalable vector graphics) format:
http://www.instructables.com/file/FW4ZN91FVW22CNW/
Dec 22, 2008. 3:03 AMgentry says:
Check out this IR sound transceiver from 1961.
Jun 14, 2009. 1:35 PMalex-sharetskiy says:
nice magazine!
Mar 14, 2009. 6:27 PMastro boy says:
hey they stole my idea! gir!!!!!!!!!!
Jun 12, 2009. 7:04 PMbrian108832 says:
sooo. i am completely new to this... i have only the basic understanding of circuitry so please excuse my question but. on the schematic it shows the output from the mp3 player with 3 lines. i understand the left and right but what is the ground?
Jul 15, 2006. 1:34 PMtrebuchet03 says:
Very cool :D There's software out there to send morse code through your speakers and also interpret code brought in through your microphone/line in... I made a really cheap serial 'radio' that did just this... but the range was not so hot :P
1-40 of 145next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:navaburo
I am a student and hobbiest. I'm into physics, linguistics, sailing, electronics, hacking (not cracking), music, and the like. I post most of my project stuff on my blog: http://hotwigati.wordpress...
more »
