Step 3Create Transmitter Circuitry
Tape or glue the compents down to a piece of cardboard, or use a breadboard.
Check out the photo of my finished board. I used an 1/8th inch female jack to make connections easier.
To test the circuit, turn up the iPod volume to MAX, play some music with alot of bass, and turn the potentiometer all the way down. The laser dot should appear to pulsate with the music, since this is an amplitude modulated (AM) circuit.
1) The academic answer: Voltages are only defined between TWO points. A single point only has a voltage insofar as a reference (ground) has been established. Any device "communicating" with the mp3 player needs to have a reference to make sense of the left and right signals.
2) The simpler but not totally correct answer: The signal needs to "return" to the source to complete the circuit. The ground allows for this completion.
Electronics is a great hobby to get into. I would recommend getting yourself a copy of the classic intro "Getting Started in Electronics".
Best of luck!
_
