3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Send Music over a Laser Beam
Step 6How does that work? And where do I go from here?
This circuit works using amplitude modulation, exactly like AM radio, except using a visible light wavelength instead of a radio frequency. The audio signal leaves the iPod as a varying voltage which forces a varying current through the laser. Then the laser's varying brightness conveys the musical information. Finaly, the phototransistor varies in resistance as the brightness on it changes. The mic amp applies a small voltage to the phototransistor and amplifies the resulting current.
A problem with this system is that at each step there is a non-linear transfer function, that is, there is distortion that occurs because the brightness changes are not always proportional to the change in voltage applied. See the screenshot below for an example, and listen to the attached audio sample.
The next step in this project would be to use pulses (like fast, computer operated morse code) to convey digital information like text, crystal-clear audio, or even video. One could even network computers with laser beams in a manner similar to fiberoptics but in open air. I will post C code for my transmitting and recieving programs.
7 comments
Mar 21, 2011. 7:32 PMZack1296 says:
YA CAKE! btw the project is awesome
Dec 19, 2007. 2:57 PMashes63 says:
hope this one works!!
Jun 17, 2009. 1:54 PMUbuntuNinja says:
That schematic is very helpful. I like how you correctly represented the different ways to wire the transformer. I was actually having difficulty figuring out which side of the transformer was supposed to be wired to what looking at the authors diagram.
Oct 27, 2008. 7:48 PMQthedude says:
have you tried this with higher frequency lasers? such as green or blue lasers? I realise that they are more expensive, but also may be able to transmit very high amounts of information compared to red lasers, to check out these go to thinkgeek.com/5a47
Dec 6, 2007. 8:07 AMashes63 says:
I used this project idea for my senior project at school and I must say, this was the best experiment. Although it didn't take me a mere couple hours, instead it turned into a two week extensive study session learning about electronics. I do have one thing to add. Instead of the schematic drawing on page 3, I made one:) I attached the photo if you want to add to the whole project page! Again, thank you for your insight and direction; I found much help reading from this.
Jun 2, 2007. 10:37 PMlookatmygrlyfont says:
lol @ the first song
May 10, 2007. 2:36 PMmicronxd says:
rofl interesting music selection... awesome project... i like the surveillanceone too
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:navaburo
I am a student and hobbiest. I'm into physics, linguistics, sailing, electronics, hacking (not cracking), music, and the like. I post most of my project stuff on my blog: http://hotwigati.wordpress...
more »
