If you know absolutely nothing about MIDI note, velocity, and pitchbend or are confused about what MIDI does and why you would want to use it, check out my What is MIDI? instructable.
Step 1: Bytes and Bits
11010111
Each 1 or 0 in this byte is a bit. The leftmost bit is called the most significant bit (or MSB) and the rightmost bit is called the least significant bit (or LSB).
Bytes of the form above are binary numbers because they are expressed using only 1's and 0's. We can convert this number to base ten as well:
11010111 in binary (base 2) = 215 in decimal (base 10)
If you need help converting numbers from binary to decimal or vice versa check out Wolfram Alpha. Type in a binary number followed with "from binary to decimal" to get the decimal equivalent. Wolfram Alpha is also great for converting to and from hexadecimal.
Wikipedia is a good resource for more information about bytes and binary.
Step 2: A Bit About MIDI Protocol
MIDI messages are comprised of two components: commands and data bytes. The command byte tells the MIDI instrument what type of message is being sent and the subsequent data byte(s) store the actual data. For example a command byte might tell a MIDI instrument that it going to send information about pitchbend, and the data byte describes how much pitchbend.
MIDI data bytes range from 0 to 127. Convert these numbers to binary and we see they range from 00000000 to 01111111, the important thing to notice here is that they always start with a 0 as the most significant bit (MSB). MIDI command bytes range from 128 to 255, or 1000000 to 11111111 in binary. Unlike data bytes, MIDI command bytes always start with a 1 as the MSB. This MSB is how a MIDI instrument differentiates between a command byte and a data byte.
MIDI commands are further broken down by the following system:
The first half of the MIDI command byte (the three bits following the MSB) sets the type of command. More info about the meaning on each of these commands is here.
10000000 = note off
10010000 = note on
10100000 = aftertouch
10110000 = continuous controller
11000000 = patch change
11010000 = channel pressure
11100000 = pitch bend
11110000 = non-musical commands
The last half of the command byte sets the MIDI channel. All the bytes listed above would be in channel 0, command bytes ending in 0001 would be for MIDI channel 1, and so on.
All MIDI messages start with a command byte, some messages contain one data byte, others contain two or more (see image above). For example, a note on command byte is followed by two data bytes: note and velocity.
I'm going to explain how to use note on, note off, velocity, and pitchbend in this instructable, since these are the most commonly used commands. I'm sure you will be able to infer how to set up the others by the end of this.
Step 3: Send MIDI Messages with Arduino- Hardware
MIDI connector Digikey CP-2350-ND
220Ohm 1/4watt resistor Digikey CF14JT220RCT-ND
Following the schematic above, solder a 220Ohm resistor to MIDI pin 4. Connect ground to MIDI pin 2 and 5V to MIDI pin 5. If the pin numbering is unclear, refer to the pictures above.
Step 4: Plug in MIDI Out
Step 5: Basic Note On, Note Off with Arduino
As I explained in step 3, the MIDI commands for note on and note off are as follows:
noteON = 10010000 = 144
noteOFF = 10000000 = 128
Both of these commands are followed by two more bytes to make a complete MIDI message, the first is note and the second is velocity (for more info about what "note" and "velocity" mean check out my introductory MIDI instructable). Note and velocity can range from 0 to 127. In this example I used notes ranging from 50 to 69 (D3 to A4):
for (int note=50;note<70;note++){}
and I set the velocity to 100:
int velocity = 100;
So when the function MIDImessage() is called in the loop() of the arduino sketch, it sends the three bytes:
Serial.write(command);
Serial.write(MIDInote);
Serial.write(MIDIvelocity);
if the "command" in the MIDImessage() function is noteON then the note will start, if it is noteOFF the note will stop.
The code below plays the notes D3-A4 in a loop, it turns on a MIDI note for 300ms then wait 200ms before turning on the next note. I wrote a MaxMSP patch (you can download the runtime version for free) that displays the incoming MIDI messages and attached it below. Here is an example video:
Step 6: Note Off with 0 Velocity
The code below does the exact same thing as the code in the last step, but it only uses note on commands. Essentially, I've replaced the following line:
MIDImessage(noteOFF, note, velocity);
with:
MIDImessage(noteON, note, 0);
Step 7: Variable Velocity and Arduino
velocity += 5;
so for note = 50, velocity = 20, then for note = 51, velocity = 25, then for note = 52, velocity = 30... and so on.
once the end of the loop() function is reached, the velocity is reset back to 20.
Here's a video of the end result, notice how the volume increases with increasing velocity.
Step 8: Pitchbend and Arduino
Below is a video demonstration of the code above. For this piece of code, pitchbend will be most noticeable in instruments with a long sustain, such as a string instrument, keep that in mind when testing the code for yourself.
You will most likely be fine using only 128 steps of pitchbend resolution, but in case you must use all 16384 steps, see the code below. Basically what I've done here is defined a variable called pitchbendVal, which varies from 0 to 16383. As I said below the "zero" pitchbend value is msb = 64 and lsb = 0. In binary this is:
MSB = 64 = 01000000
LSB = 0 = 0000000
(remember MSB and LSB are 7 bit numbers)
putting these values together we get:
1000000 0000000
MSB LSB
or
10000000000000
which translates to 8192 in decimal
so now the "zero" pitchbend value is 8192.
You'll also notice I had to break the variable pitchbendVal into two 7 bit parts to send out via MIDI message:
MIDImessage(pitchbend, (pitchbendVal&127), (pitchbendVal>>7));
the first part, pitchbendVal&127, returns the least significant 7 bits of pitchbendVal
the second part, pitchbendVal>>7, returns the most significant 7 bits of pitchbendVal
see & and >> on the Arduino reference page for more info.
Step 9: Receive MIDI Messages with Arduino
an Arduino synthesizer that uses MIDI messages to construct audio waveforms
a device which uses MIDI to trigger mechanical events, like the ringing of different sized bells
a MIDI to control voltage(CV) device- communication between MIDI and analog synthesizers
Parts List:
1N4148 diode Digikey1N4148-TAPCT-ND
10kOhm 1/4watt resistor Digikey CF14JT10K0CT-ND
470 Ohm 1/4watt resistor Digikey CF14JT470RCT-ND (I used 2x220 instead)
6N138 optocoupler Digikey 751-1263-5-ND
The hardware setup is slightly more complicated for receiving MIDI than it is for sending. As you can see in the schematic above, you have to set up an optoisolator in between the MIDI jack and the Arduino. If you are confused about the MIDI pin connections, refer to fig 1. I set this circuit up on a breadboard in figs 4 and 5.
The following code receives these messages, reads them, and stores them appropriately. See the comments for more information.
To make sure that everything is working properly, try the code below. This code turns the led at pin 13 on briefly when it receives a note on message for MIDI note 60 (middle C). Notice how I included "&& velocityByte>0" in the if statement- this makes sure that we are dealing with a note on statement, if you don't include this the light will blink for both note on and note on with velocity = 0 (note off) messages.
If you want to do a lot of stuff in the main loop, or if you are expecting to receive a lot of MIDI data and timing is important to you, you can also try using a timer interrupt to periodically pause the main loop and check if there is incoming MIDI. It will look something like this:
Step 10: Examples
And here is the code for those applications:
single pixel moving around, triggering MIDI (only uses x and y accelerometer):
four pixels bouncing (only uses x accelerometer, uses x gyro to clear pixels):
Visit Our Store »
Go Pro Today »
I'm really having issues getting midi input as well. I've tried many different setups and opto couplers, including this exact instructable - without luck.
I tried your code, but you haven't defined NOTE_ON, NOTE_OFF, PITCH_WHEEL and CONTROLLER anywhere. What did you intend to put into these variables, or are they #define instructions that you forgot to include here?
all the best
Søren
Referring to step 9. I understand that digital pin 0 (RX0) must be disconnected when uploading program to Arduino via USB cable.
After uploading the program to arduino, pin 0 (RX0) will be reconnected to receive input from MIDI jack. Can I also reconnect the USB cable to power the arduino? Or do I have to power the arduino using external power source such as battery pack?
Thanks and regards,
electronicrookie
http://en.wikipedia.org/wiki/MIDI_beat_clock
scroll down to the "system real-time messages" in this table:
http://www.midi.org/techspecs/midimessages.php
you just need to check to see what type of messages you are receiving with the midi in, if they are equal to 11111000, then you know it is a timing clock message and you can have this modulate the timing of your midi out. does that make sense?
Thanks for this instructable. It's been really handy. I had problems with the MIDI input, with some MIDI devices. I discovered that this was to do with MIDI active sensing. Here's my code for reading the MIDI port that takes into account for MIDI active sensing.
byte incomingByte=0;
byte notebyte=0;
byte velocitybyte=0;
byte statusbuffer=0;
boolean arp_triggernext=false;
boolean firstbyte;
void MIDI_Poll(){
if (Serial.available() > 0) {
do {
// read the incoming byte:
incomingByte = Serial.read();
if (incomingByte>247) {
// this is where MIDI clock stuff is done
switch (incomingByte){
else if (incomingByte>240) {
statusbuffer = 0;
//sysex stuff done here
else if (incomingByte>127) {
statusbuffer = incomingByte;
firstbyte = true;
notebyte = 0;
velocitybyte = 0;
else if (statusbuffer!=0) {
if (firstbyte == true) {
// must be first byte
notebyte = incomingByte;
firstbyte = false;
else {
// so must be second byte then
velocitybyte = incomingByte;
//process the message here
if (statusbuffer == NOTE_ON && velocitybyte != 0) {
//MIDI note on subroutine
else if (statusbuffer == NOTE_OFF || (statusbuffer == NOTE_ON && velocitybyte == 0)) {
//MIDI note off subroutine
else if (statusbuffer == PITCH_WHEEL){
//pitch bend wheel
else if (statusbuffer == CONTROLLER){
if (notebyte==1) {
//MIDI_modwheel_level = velocitybyte;
//now clear them for next note
notebyte = 0;
velocitybyte = 0;
firstbyte = true;
} while (Serial.available() > 0);
Thanks for the Instructable - the MIDI out section's fantastic, and the tutorial as a whole inspired me to buy an Arduino. Great work!
I've not been able to get MIDI in messages to light an LED though. It's to do with the non-Arduino components, I think: I took a risk and connected the MIDI In directly to my Arduino Nano, and it then works fine - so the issue's not Arduino compatibility. I've tested continuity where I can (resistors, diode) and tried 2 different optocouplers. My optocoupler was Lite-On brand, but I've compared the specs and the pinout/internal circuitry are the same as the device you specify. No oscilloscope here I'm afraid!
http://arduino.cc/en/Reference/SoftwareSerial
but if your incoming midi is coming in with separate channels, then you can read them both from pin 0. do the following:
byte commandByte;
byte noteByte;
byte velocityByte;
void setup(){
Serial.begin(31250);
cli();//stop interrupts
//set timer2 interrupt every 128us
TCCR2A = 0;// set entire TCCR2A register to 0
TCCR2B = 0;// same for TCCR2B
TCNT2 = 0;//initialize counter value to 0
// set compare match register for 7.8khz increments
OCR2A = 255;// = (16*10^6) / (7812.5*8) - 1 (must be <256)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS11 bit for 8 prescaler
TCCR2B |= (1 << CS11);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
sei();//allow interrupts
ISR(TIMER2_COMPA_vect) {//checks for incoming midi every 128us
do{
if (Serial.available()){
commandByte = Serial.read();//read first byte
noteByte = Serial.read();//read next byte
velocityByte = Serial.read();//read final byte
MIDImessage(commandByte,noteByte,velocityByte);
while (Serial.available() > 24);//when three bytes available
//send MIDI message
void MIDImessage(int command, int data1, int data2) {
Serial.write(command);//send command byte
Serial.write(data1);//send data byte #1
Serial.write(data2);//send data byte #2
void loop(){
//do whatever here
does that work? are your keys and drums coming into the arduino on separate channels?
byte commandByte;
byte noteByte;
byte velocityByte;
byte newCommandByte = 0;
byte newNoteByte = 0;
byte newVelocityByte = 0;
boolean newote = false;
void setup(){
// turn on CTC mode
do{
channel = commandByte&B00001111;//last four bits of commandByte
if (channel ==10){//midi channel of your drums
newCommandByte = commandByte &B11110000;//change newCommandByte to commandByte with midi channel 0
noteByte = Serial.read();//read next byte, this gets thrown away
newVelocityByte = Serial.read();//read final byte and set to newVelocityByte
newNote = true;//let's us know there is a new note to send out
} else {//midi channel of your keys
newNoteByte = Serial.read();//read next byte and set newNoteByte
velocityByte = Serial.read();//read final byte, this gets thrown away
if (newNote){//
newNote = false;
//send out combined midi on channel 0
MIDImessage(newCommandByte,newNoteByte,newVelocityByte);
//send MIDI message
void loop(){
//do whatever here
byte commandByte;
byte noteByte;
byte velocityByte;
byte noteByte1;
byte noteOn = 144;
//light up led at pin 13 when receiving noteON message with note = 60
void setup(){
// pinMode(13,OUTPUT);
//digitalWrite(13,LOW);
void checkMIDI(){
do{
//if (commandByte == noteOn){//if note on message
//check if note == 60 and velocity > 0
//if (noteByte == 60 && velocityByte > 0){
//digitalWrite(13,HIGH);//turn on led
void loop(){
checkMIDI();
MIDImessage(commandByte, noteByte, velocityByte);
void MIDImessage(int commandByte, int noteByte, int velocityByte) {
Serial.write(commandByte);//send note on or note off command
Serial.write(noteByte);//send pitch data
Serial.write(velocityByte);//send velocity data
println (commandByte);
to the loop(), can you copy what gets printed and post it?
By Amanda Ghassaei
July 2012
http://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
byte commandByte;
byte noteByte;
byte velocityByte;
byte noteByte1;
byte noteOn = 144;
void setup(){
void checkMIDI(){
do{
void loop(){
checkMIDI();
noteByte1=noteByte;
MIDImessage(commandByte, noteByte1, velocityByte);
void MIDImessage(int commandByte, int noteByte1, int velocityByte) {
Serial.write(noteByte1);//send pitch data
By Amanda Ghassaei
July 2012
byte commandByte;
byte noteByte;
byte velocityByte;
byte noteByte1;
byte noteOn = 144;
void setup(){
void checkMIDI(){
do{
void loop(){
checkMIDI();
noteByte1=noteByte;
//delay(250);
//digitalWrite(13,LOW);//turn led off
I did 2 circuits with 2 - 6N138, one gets the midi drums, the other receives midi keyboard according to the Tx, however I can not manipulate the bytes, the sound gets all mixed up, I can not put the note on the keyboard of my message Midi end. MidiMessage (Status, note, velocity)
The battery comes on channel 10, channel 1 on the keyboard. I can not make the arduino identify one another, and finally put the note on my keyboard, the final message (Status, note keyboard, drums velocity)
Please help me with this code. Thank you.
Hi Amanda
Congratulations on the publication of their work. I'm sure they inspire many people.
I play with my son ten years. He plays drums and I play electronic keyboard. I would like to put a third person in this group and it would be a bassist, but he would own the arduino. lol
Through midi cable, because the battery of my son's electronics.
My idea is as follows. when he touched the kick drum, the bass on my keyboard touch, but he would play the same note I'm playing. For example, my hand would be on the C note, my son would play 123 ... 123, bass keyboard touch C, C, C. .. C, C, C. If I touched the note G, the arduino would do the same thing, he would catch the rhythm of the drum of my son, and put the note in the middle of the sun from midi message.
I think the code of arduino should have a variable which would take note of my keyboard, and replace the bass drum note from my son (because the bass drum is always the same note, if I'm not mistaken is C2 or C3)
I looked at many sketches of arduinos midi, but there are so many bits and Bytes I got a little lost. I am a layman on the subject, but with your help I believe I can. And you can take this idea and create something through their creativity. Thank you.
I'm new to all of this so I'm not quite sure what I can check on MIDI In for continuity. I've noticed that testing Pin4 on my MIDI Out against the TX send tests fine, but none of the Pins on the MIDI in test against the RX pin. Not sure how the optocoupler affects basic continuity testing though.
